Still have hissing noise when pressing brake pedal!
Old Nov 6, 2012 | 11:30 AM
daboss085's Avatar
Default Still have hissing noise when pressing brake pedal!
I still have the hissing noise after I changed my brake booster and brake hose, and also did the front pads and rotors. The brakes so stop much better, but when I press on the brake I still have the hiss sound. any ideas? normal on a s-types? BTW I also did a brake flush last week as well! thanks again guys...
Old Nov 6, 2012 | 12:14 PM
Mikey's Avatar
Is the hiss constant while your foot is on the pedal, or just a second or two as the brakes are being applied? If it's the latter, I'd say 'normal', and that you've got excellent hearing.
Old Nov 6, 2012 | 08:09 PM
daboss085's Avatar
its just a quick second or 2. it does not hiss while the brake is pressed down, only while I am pressing it.
Old Nov 7, 2012 | 10:18 AM
bfsgross's Avatar
U may have a brake booster problem. Does the tach wander when pressing on the brake pedal?
Old Nov 7, 2012 | 11:30 AM
JagV8's Avatar
Why would the tach wander?
Old Nov 7, 2012 | 08:45 PM
bfsgross's Avatar
Brother, that "Hiss" isn't from a Black Mamba... it may be a leak. Vaccume leaks can periodically make the tach wander as the ECU tries to richen up the lean condition. If the leak is only produced during depressing the brake pedal, the ECU may not throw a CEL due to vaccume quickly building up following each pedal depression.
flyrr100
Mar 14, 2016 06:37 AM
neruda
Oct 18, 2015 01:19 PM
Jefro
Sep 15, 2015 01:44 PM
daniel06
XE ( X760 )
Sep 15, 2015 07:07 AM
hen555
Sep 7, 2015 11:13 PM
