STR Fan on, why?
Old May 26, 2011 | 09:48 AM
chrislynn5's Avatar
Default STR Fan on, why?
My previous Stype 3.0, the fan only came on when there was something wrong with the coolling system. It came on as a failsafe to protect the engine.
My 2005 STR comes on often? Even when the outside temp isn't so hot???
It's not staying on after the engine is turned off though.
The engine does run hot, you can cook an egg on the front panels and hood.
Is this normal?
Thanx.
Old May 26, 2011 | 09:49 AM
phd12volt's Avatar
thermostat most likely, however i know my fans are on sometimes. running live data in the car, i am about 205 operating temp. This is being grabbed through the CAN network
Old May 27, 2011 | 04:15 AM
JagV8's Avatar
That's not how it's meant to work. It should come on when any of several things occur but it's only "protecting" in the sense that there is (as with any car) a safe operating temperature range.
The STR is no different.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Manjag
Oct 1, 2015 05:34 PM
SoCalJagS
Sep 27, 2015 09:20 AM
