Stype 2.5 v6 2002 Misfire Cylinder 5
Old Feb 12, 2021 | 04:23 PM
Magdy Tawfik's Avatar
Default Stype 2.5 v6 2002 Misfire Cylinder 5
I have engine misfire and DTC codes p0305 and 1316 the attached is the scan tool output for all sensors and graphs for O2.
can someone please help me to understand why does O2 sensor 1 bank 1 is fluctuating? I have replaced all sparks plug and bank 2 coils as had DTC p0300 after replacing got the existing p0305.
N.B. I have removed the catalytic converter from bank 1 as got clogged until sort out the misfire problem.
File Type: docx
File Type: xlsx
File Type: txt
File Type: txt
Old Feb 13, 2021 | 02:23 AM
JagV8's Avatar
With no cat, at least the back pressure, EGR, O2 will be wildly wrong and I suspect the PCM just cannot cope.
I would give up wondering and instead fix what clearly needs fixing.
Jag in Aust
Mar 24, 2020 09:26 AM
Jag in Aust
Jan 24, 2020 07:57 PM
Eugene Smith
Jul 4, 2019 02:58 PM
DanSime
Feb 24, 2016 11:55 AM
lmerritt
Mar 4, 2014 02:37 AM
