Stype 4.2 2004
Old Sep 4, 2016 | 01:23 PM
middlemarsh's Avatar
Default Stype 4.2 2004
I have just bought a S Type 4.2 2004 and on the 140 mile drive back the orange light on the dash came on saying gearbox fault.Then I turned the ignition off and restarted it,the light and message went off and hasn't come on again.Could this be the sensor or possible it needs a ATF change Ant ideas?
Old Sep 4, 2016 | 06:19 PM
NBCat's Avatar
What is the age and condition of the battery? A failing or weak battery can cause all sorts of electrical faults. With the ignition off, the battery must have 12.2 volts or higher across the terminals, if not, the battery must be replaced.
Old Sep 5, 2016 | 10:39 AM
clubairth1's Avatar
Community Influencer
You do need to service the transmission. This would be new fluid, sealing sleeve and a new pan/filter. Be sure and have the TCM software updated to the latest version too.
Might be something as simple as low fluid level.
Old Sep 5, 2016 | 02:43 PM
Thanks for the replies.I have seen that other people have had problems when its wet as the TCU does not like getting damp.I think ive heard that somewhere before.
Old Sep 6, 2016 | 01:54 AM
JagV8's Avatar
Damp? The TCM is inside the oil in the autobox... Damp it is not.
rjcl004
Apr 26, 2016 04:48 PM
Eel
Apr 5, 2016 05:25 PM
XxSlowpokexX
Apr 4, 2016 05:38 PM
DEklof
Mar 28, 2016 12:07 PM
phil51
Mar 25, 2016 08:18 PM
