SType blows hot ONLY on BOTH side and back vents - RESOLVED
Old Mar 18, 2019 | 04:41 PM
Mason Fox's Avatar
Default SType blows hot ONLY on BOTH side and back vents - RESOLVED
I have a 2005 Jaguar Stype, AC blows cool, compressor comes on, but ever since I had the the Heater Control Valve fixed it blows hot on both the drivers, and passengers side vents. Also blows hot thru the back vent. The heater didn't work at all before having the valve fixed, I bought a new climate control module hoping it would fix it but as i wait to have it replaced im starting to question whether its the right move or not.
Old Mar 18, 2019 | 10:39 PM
aholbro1's Avatar
It's easy to blame the water valve...even when they're new, they have a high propensity for failure. However, that being said, the road to success is illuminated by Karl's epic HVAC troubleshooting guide. It should be in the stickies by now. Follow it stem to stern and you'll find the culprit. My battery is about to die, so if you can't find it, I reckon Karl or someone else will happen along shortly to help you with a link.
Old Mar 18, 2019 | 10:47 PM
kr98664's Avatar
Here you go:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Specifically, see post #2 to test that new DCCV. No assuming (Danger! Danger!) it's good just because it is new. Also check fuse F32 under the hood.
After that, please follow the links near the end of post #2. They will take you to very detailed instructions to test the circuit powering the DCCV. In some cases on 2003+ cars, the DCCV can draw too much current and burn up the control panel. Follow those instructions to make sure the control panel has not been damaged.
If damage is found, your new DCCV is at fault and needs to be replaced. You can send your damaged panel to be repaired at a reasonable cost. If you want to try your new panel instead, first make sure the new DCCV didn't burn up the original panel.
Old Mar 19, 2019 | 02:42 PM
Brutal's Avatar
Originally Posted by kr98664
here you go:
specifically, see post #2 to test that new dccv. No assuming (danger! Danger!) it's good just because it is new. Also check fuse f32 under the hood.
After that, please follow the links near the end of post #2. They will take you to very detailed instructions to test the circuit powering the dccv. In some cases on 2003+ cars, the dccv can draw too much current and burn up the control panel. Follow those instructions to make sure the control panel has not been damaged.
If damage is found, your new dccv is at fault and needs to be replaced. You can send your damaged panel to be repaired at a reasonable cost. If you want to try your new panel instead, first make sure the new dccv didn't burn up the original panel.
i would say no your new valve didnt blow the ac panel but not checking it after the old dccv went out is the problem. It was bad and should have been replaced with the valve. Why i always check the ground outputs to the dccv from the side of the dash to verify theyre good after a leak from, onto the dccv
i have 3 repaired panels and 1 for the navigation cars ready to go pm if thats your issue
Old Apr 7, 2019 | 07:41 PM
Mason Fox's Avatar
Update** replaced the CC and it AC is working like new. All vents blowing ice cold. Hope this helps someone whos having odd AC problems. Did it at home with 3 star screws, 15 minuets, and hope. Easier Radio/CC replacement Ive ever done.
Old Apr 12, 2019 | 04:51 AM
thetrashcanman's Avatar
Hi mate I have just been reading the guide when you say the CC do you mean the HCCV? or something entirely unrelated? As my S type R has similar problem
Old Apr 12, 2019 | 08:41 AM
Brutal's Avatar
Yeah do you meen climate control module???? CCM??? We try to be exact even if jaguar land rover doesnt and cant seem to call parts the same names between the workshop manual, sdd, parts and warranty coding. It's agravating af
Old Apr 12, 2019 | 01:12 PM
Mason Fox's Avatar
Sorry, yes the Climate Control module. Ill also note that it didnt give me a code for the blown Climate Control Module when i checked codes. My radio was also blown to where the volume/buttons would only work on certain occasions. It was a quick fix, 10ish screws and a few clip plugs for the whole center console.
Old Apr 12, 2019 | 01:22 PM
Brutal's Avatar
yeah it wont throw codes. You have to pin the ground signal from the CCM to the DCCV. no operation and you have blown circuit/s in the board. When I repair I do both and beef them up so they're not so fragile.
BrentGardner
Mar 9, 2019 06:34 PM
aholbro1
Feb 5, 2017 10:15 AM
jtdurett
Nov 11, 2015 08:06 PM
jazzman20014
Oct 26, 2015 04:15 PM
randyshear
46
Jan 13, 2013 08:47 AM
