Sunroof drain question.
Old Jun 21, 2020 | 04:03 PM
ZenFly's Avatar
Default Sunroof drain question.
My left front drain is not draining.. I used a 6ft piece of 120lb stiff fishing leader line down from the top and it goes all the way down behind the front wheel 5-6in from the end but I can't get the stoppage out... Will that section be exposed if I remove the wheel well cover.. I can change my fuel filter while I'm in there too.. Thanks
Old Jun 21, 2020 | 05:49 PM
Scotlad's Avatar
Would an air nozzle and air tank or compressor be able to blow out the obstruction? I did that recently to the gas filler drain under the flap.
Old Jun 21, 2020 | 06:05 PM
ZenFly's Avatar
Thanks but I fear blowing the line off the fitting inside and then have to remove my headliner to repair that.. I've researched this and that has happened.. If nobody knows I'm going to open the back of that wheel well and see if it's there.. It's where the water runs out on the other side..
LT1 jaguar
Mar 5, 2020 09:40 PM
Chairman6807
Oct 26, 2019 08:15 PM
mikebaker3
50
Jul 20, 2019 11:42 AM
curtis505
Aug 28, 2018 08:04 PM
curtis505
Aug 23, 2018 08:33 AM
