Sunroof Leaking Problem!!!!
Old Feb 19, 2015 | 09:36 PM
kelbymorgan's Avatar
Default Sunroof Leaking Problem!!!!
I bought this car as a project. It needed a new sunroof assembly. I purchased an assembly from our local salvage. The new sunroof Works great, but it leaks when at the carwash. I ordered a new seal(XR841581) and put it on the glass . It seemed to help some. The new seal does not leak when just pouring water over the glass, but it leaks when spraying the seal with the pressure washer at the carwash. Are these seals engineered to withstand the high psi at the carwash? Has anyone else encountered this problem?
I attached some pics of where it is leaking.
Attached Thumbnails Sunroof Leaking Problem!!!!-jaguar-sunroof-leak-2.jpg   Sunroof Leaking Problem!!!!-jaguar-sunroof-leak-1.jpg   Sunroof Leaking Problem!!!!-jaguar-sunroof-leak-3.jpg   Sunroof Leaking Problem!!!!-jaguar-sunroof-leak-4.jpg
Old Feb 19, 2015 | 09:39 PM
As you can see, I have not placed my headliner back yet. I have also adjusted the glass with the four screws located under the glass, and that did not seem to help.
sogood
Sep 15, 2015 07:35 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
