Surging at 1500 RPM
Old Aug 17, 2010 | 11:39 AM
kmrod22's Avatar
Default Surging at 1500 RPM
Hopefully there might be some suggestions out there. I have an 03 STR with about 85K mi. Lately I've had a problem with the car kind of surging sputtering at around 1500 rpm while I'm driving down the road. It is definitely more noticible when it's unders slight load going up hill.
I had a mechanic friend of mine check to see if it was throwing any codes and it wasn't. However when this started the key fob codes went out which happened one other time when a worn out e-brake threw 30+ codes and killed the programming.
Anyway looking for the most likely source of the sputtering. Also of note there is no detectible change or other sound other than RPM variation when this occurs.
Any help would be much appreciated.
Old Aug 17, 2010 | 11:57 AM
JagV8's Avatar
Sounds like misfires. Or an air leak, maybe PCV/EGR. But could be related to fuel pressure. Cheap item is fuel filter - when was it last changed?
Check air filter is not filthy and is properly seated, as that's even cheaper
Old Aug 18, 2010 | 11:19 AM
Mafioso's Avatar
I vote misfires.
Old Aug 18, 2010 | 01:02 PM
MyBlackCat's Avatar
Maybe torque converter trouble.
Old Aug 18, 2010 | 01:18 PM
kmrod22's Avatar
I'll try the fuel filter first as the air filter is new and see what happens. Interestingly in driving the car yesterday after about a 45 mile drive on the fwy the low rpm problem wasn't there or at least not noticeable if it was. As for the misfire wouldn't it likely fire a code?
Old Aug 18, 2010 | 01:30 PM
JagV8's Avatar
You'll only get codes if a problem is so consistently bad as to flag them.
Old Aug 18, 2010 | 02:08 PM
bfsgross's Avatar
JagV8, Sounds like good diagnostic troubleshooting...fuel...spark...vaccume leak...
Old Aug 18, 2010 | 02:29 PM
JagV8's Avatar
Aww, I've been rumbled!
Sticking to the basics does tend to work
bdboyle
Sep 16, 2019 05:58 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 01:59 AM
dansxj6
Sep 28, 2015 08:02 AM
