suspension noise
Old Nov 15, 2008 | 08:29 AM
bigdaddywuff's Avatar
Default suspension noise
I have a 2001 S-type 4.0. It was involved in a front end collision. unfortunately they repaired it so now the car sounds like a truckload of srap metal. Everytime the car move or turns all i hear is what sounds like the suspension creeping like on old bed. Is it possible something got damaged that would cause the whole car to make this noise. You can really hear it if you drive slowly over a speed bump or when turning.
Old Nov 15, 2008 | 12:13 PM
marktmv's Avatar
Default RE: suspension noise
I had a similar noise after changing my sway bar bushings. A bit of graphite lube eliminated the creaking.
Just don't use regular bearing grease, it deteriorated quickly and the noise comes back - i learned that the hard way...
Old Nov 15, 2008 | 12:17 PM
12RM's Avatar
When the ball joints are dry they can creak and groan when steering/turning, most noticeable at slow speeds. One of mine did just that, no movement or wear when tested.
Old Nov 15, 2008 | 10:32 PM
Venumb's Avatar
What parts sustained damage? What all was replaced? Car pulling left or right at all?
Old Nov 15, 2008 | 10:56 PM
harounq21's Avatar
might be the upper control arms
Old Nov 15, 2008 | 11:21 PM
whiteSTR's Avatar
Bushings.. impossible to tell which one without hearing it in person, but just take it back to wherever you had the car repaired... They might tell you that the noise had nothing to do with the repair they performed, but they might be able to identify whatever is making the noise so you can fix it yourself.
Old Nov 17, 2008 | 08:35 AM
Ill look into it tried to take to dealer again they told me suspension shocks and springs but i dont agree but will keep you posted thanks for the help
XJ8JR
26
Aug 8, 2020 09:38 PM
JimC64
31
May 30, 2016 03:04 PM
driver safz
Sep 26, 2015 06:01 AM
redgear
Sep 18, 2015 10:05 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
