Test pipes
Old Dec 7, 2012 | 05:19 PM
QuartzSTypeR's Avatar
Got a couple quick videos. GoPro isn't very good sound-wise, but you should get the idea:
https://www.youtube.com/watch?v=WM4QobLEUcU
https://www.youtube.com/watch?v=4QULREnTYB0
Old Dec 7, 2012 | 05:51 PM
goblue90's Avatar
Wow, that's loud... But it sounds freakin awesome!!!!
Old Dec 7, 2012 | 07:36 PM
bfsgross's Avatar
Sounds like a late model XKR. Enjoyable for short trips.
Old Dec 7, 2012 | 11:32 PM
Indeed. If it were my daily driver, I wouldn't want it that loud; but for occasional driving its fine for now.
Old Dec 9, 2012 | 11:28 AM
Michael Star's Avatar
Vid is up, and yea it is kinda loud. Looking at some 3" resonators to put on it soon.
Test Pipes - YouTube
Old Jan 6, 2013 | 07:42 PM
If someone is going to do test pipes, here is how to keep your CEL from coming on.
(Sorry for the blurry pics)
First buy 2 spark plug anti-foulers (Part #42009)
The part that sucks is you have to drill on large enough for the o2 sensor to pass through. You need to use a 1/2" drill bit to make the hole. A drill press makes this job so much easier. You only need to drill 2
Before:
After
Screw them together
Put the o2 into it
After that put it back into the car and hook it up. No CEL
Attached Thumbnails Test pipes-708429_10151410117302853_595293680_o.jpg   Test pipes-708762_10151409985227853_1947590335_o.jpg   Test pipes-728977_10151409973487853_1605869998_o.jpg   Test pipes-728732_10151409973967853_1899261020_o.jpg
Old Jan 6, 2013 | 07:56 PM
bfsgross's Avatar
Default Excellent
Mike, excellent tutorial. Even Billy Mays (may g-d rest his soul) would have been proud.
Old Jan 6, 2013 | 08:29 PM
  #28
JgaXkr's Avatar
I used the low profile banjo style on my car as clearance is an issue.
O2 Spacer - Oxygen Sensor Spacer - CEL / MIL Fix - Oxygen O2 Sensor Adapter - O2 Sensor Extender
Old Jan 7, 2013 | 01:58 AM
JagV8's Avatar
Michael - Which codes were you getting?
JgaXkr - same question
Old Jan 7, 2013 | 05:49 AM
  #30
JgaXkr's Avatar
I get no codes & the o2 test passes the readiness as well.
Old Jan 7, 2013 | 06:34 AM
  #31
I don't get any codes either. If you don't add some type of spacer you will most likely get p0420 and p0320 (?). Both are related to the cats (left and right) stating that they are below threshold values.
Old Jan 7, 2013 | 07:31 AM
  #32
JagV8's Avatar
I meant: which codes did you get that meant you put those extra things on?
Or did you just assume you'd get or might get codes but don't actually know?
Old Jan 7, 2013 | 10:00 AM
  #33
bfsgross's Avatar
He assumed the codes would show.
Old Jan 7, 2013 | 12:29 PM
  #34
JagV8's Avatar
Er... why?
And if they would have been cat efficiency ones then it must mean there's unburned fuel+air which sounds like a fuelling problem, right?
Old Jan 7, 2013 | 12:49 PM
  #35
No, cats being below threshold means that the cats are not doing their job, and since they are no longer there on a test pipe, it will throw a code. The air/fuel mix is done by the first set of o2s. I should have specified that this was done on the 2nd set of o2s.
Old Jan 7, 2013 | 01:01 PM
  #36
JagV8's Avatar
Cats are there to burn any unburnt fuel+air. (That's the emissions stuff.) Cat efficiency codes mean it's not happening but also mean there was unburnt fuel+air or bad fuelling. What else are you saying such codes can mean / how else can they occur?
edit: I suppose they can also trigger (falsely) if you have an exhaust leak, but you'd want to fix that!
Old Jan 7, 2013 | 01:45 PM
  #37
The issue is that the computer is seeing the same values on both inline o2s which it interprets as a bad cat. There will always be unburnt fuel in the exhaust as a byproduct of combustion. And you are correct, the cat chemically converts the leftover, but by just moving the 2nd o2 our of the direct line of the exhaust stream, it won't throw the code. That to me means that combustion is sufficient enough to make it past the 2nd o2 without a cat in place and pass emissions.
This is the actual fault code
Catalyst System Efficiency Below Threshold
I hope this was a bit more clear
Old Jan 7, 2013 | 04:09 PM
  #38
JagV8's Avatar
Thanks. I guess it would fail a tailpipe test (which is what is done here).
On these cars the upstream & downstream O2s are completely different but I suppose the computer could translate the readings and be upset.
aholbro1
Dec 29, 2024 06:46 PM
xjrjag
Oct 24, 2024 03:09 PM
JWheeler
Nov 22, 2019 08:28 AM
XJ8JR
Sep 24, 2015 05:10 PM
Tim Goz
Sep 17, 2015 09:11 AM
