Test Report
Old Oct 8, 2016 | 03:34 PM
Muhammad Umer's Avatar
Default Test Report
Dear Team,
i am looking to buy an S type R 2006 supercharged, however it goes on fails safe mode after trying for about 30 minutes, kindly check the report and let know how bad it is and what exactly is the problem, and can it be fixed and the engine has to be overhauled?
Old Oct 8, 2016 | 03:35 PM
after driving for about 30 minutes*
Old Oct 8, 2016 | 03:57 PM
dana0330's Avatar
Looks like you have a vacuum leak in bank2 and a problem with the coolant pump. Check for vacuum leaks. I had one that drove me nuts and found it was the O-ring on the oil dipstick.
Old Oct 9, 2016 | 08:47 AM
JagV8's Avatar
You must fix that P2601 - typically change IC pump.
Old Oct 9, 2016 | 04:59 PM
gm_jim's Avatar
I had a lean code for one bank only. It turned out to be loose bolts attaching the downpipe to the exhaust manifold. I tightened them up and the LT trims returned to a normal range and the lean code did not return.
This part of the exhaust is before the first 02 sensor. It was fooled by air entering the system at the downpipe/manifold. The bolts are easy to reach with a ratchet extension of about 18".
MichaelJohn
Sep 7, 2016 07:19 PM
leep123
16
Sep 2, 2016 04:37 AM
Peter Jones
Aug 24, 2016 08:12 PM
