Throttle Position Sensor SOLVED!
Old Aug 3, 2018 | 02:23 PM
OnebadassXJR's Avatar
I did it, it works so far. All strange lights/warnings/codes GONE!! 2004 XJR.
Old Aug 7, 2018 | 07:45 AM
Paul755's Avatar
Any one know if the Motorcraft TPS unit for the 2006 Lincoln LS has the same resistance range? Genuine Motorcraft units are available for around $50.
Old Jul 28, 2019 | 11:20 AM
Gary Holland's Avatar
Originally Posted by baldeagle15
The non-availability of a new replacement Denso 198500-3300 TPS has been the subject of much discussion on these forums. I am pleased to report that I found one on the internet for about$100. I cleaned the throttle body on my '04 V6 and installed it and it works perfectly! No reprogramming or Jag voodoo required! The only trick is to have the bit for the TPS screws. This is a common 5-point torx TS20 tamper-resistant bit, not a Jaguar specialty bit. Regular torx are 6-point and don't work. A set including the correct bit is available on Amazon for $8.99. I ordered the TPS from automotivepartsfactory.com. It was advertised for the X-type, but works perfectly on my S-Type (and, I expect, the XKs as well). I hope this helps you guys avoid having to buy a new throttle body from Jaguar. Carl
A seies if photos from my dash coukd this also be to do with the thrittle body issue.
Also the speedo drops out and the rev counter too.
Happens every couple of months and clears after puging in diagnostics and clearing numerous fault alarm that are unrelated
Old Jul 28, 2019 | 12:18 PM
MyBlackCat's Avatar
I would start by charging the battery fully. These faults occur with low battery voltage. Car needs over 14 volts when running around 12.7 when not. might not solve the problem but worth a try.
How old is battery? Does car get daily use? short drives can kill battery.
Old Jul 28, 2019 | 01:09 PM
Thanks Black cat. I will check the battery out .
I use the car an a daily basis. Not sure how old battery is.
Reards
Gary
Old Sep 10, 2019 | 10:29 AM
Update, my China TPS has failed again, on the hunt for an OEM Denso now.
Old Sep 10, 2019 | 11:18 AM
Default ok so far
hi Black cat
i had my battery checked and it was only dishing out about 12.5 so i got a replacement and all has been ok up till now. 6 weeks.
if anything changes i will let you know
Old Sep 10, 2019 | 01:32 PM
  #28
joycesjag's Avatar
I couldn't find a new one. I did purchase a used one from ebay a couple months back for about $50.00. It came with a 30 day guarantee. No problems with it. Used throttle bodies were going for around $125.00 on ebay.
This was for Jon89's old 2005 S Type 3.0, which my friend Todd now owns.
Old Sep 11, 2019 | 07:06 AM
Picked one up from a yard in WA State with 53k on it, fingers crossed.
Old Sep 11, 2019 | 07:41 AM
  #30
joycesjag's Avatar
Good luck!
What was the cost?
Old Sep 23, 2019 | 08:49 PM
  #31
nheald's Avatar
Default Throttle position sensor mount screws
I have a early 2002 S-Type 3.0 V6 with the Older Style Throttle body. What Torx size are the 5 flute mounting screws for the Throttle Position Sensor ?
Thank you.
Old Sep 23, 2019 | 09:16 PM
  #32
motorcarman's Avatar
I just replaced a 2002 throttle assy today but I did not look at the tamper-proof Torx Plus screws.
I am not walking down to my shop tonight but I will check in the morning!!
My guess will be T25 but why not buy a set?
Amazon Amazon
Old Sep 24, 2019 | 07:31 AM
  #33
Good luck!
What was the cost?
$50 and it did NOT work. I swapped it w/bad china one, the china one worked perfect, put the oem used one back in got ALL faults as soon as I turned the key to on without even starting it, seller said they we're tested,lol NOT> I just bought another china one, need to be on the road, if it lasts 7-9 Monthas again I am good, plus it is so easy to swap.
Old Sep 24, 2019 | 08:32 AM
  #34
nheald's Avatar
https://www.amazon.com/Ram-Pro-Point...GVAY8XKK0DDH1Z
The reason I asked the question, my son tells me the TS25 seems too small and the TS27 is too large.
Old Sep 24, 2019 | 03:25 PM
  #35
joycesjag's Avatar
Google search "5 point torx tamper resistant" its a set of bits that will fit. I am not sure which 1 at this time, sorry.
Old Sep 24, 2019 | 09:42 PM
  #36
Like the amazon set I posted in #32?
bob
Old Sep 25, 2019 | 07:50 AM
  #37
Another update. Got a Jag USED tps off a 56k mile XJR and it didnt work, sent it back. Got another china one, put it in as soon as I hit the key got all the errors again just like Jag one, then put on the first china one that was periodically acting up back in and presto again it works! WTF? Ready to buy a for sale sign.
Old Sep 25, 2019 | 02:48 PM
  #38
joycesjag's Avatar
[QUOTE=motorcarman;2130631]Like the amazon set I posted in #32?
/QUOTE]
Yep!!! Sorry Bob, my brain did not compute.
Aus V8S
Nov 13, 2015 11:01 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
OkieTim
Sep 8, 2015 04:48 PM
gregster41
Sep 6, 2015 06:51 PM
