timing chain tensioners
Old Dec 28, 2014 | 07:22 PM
wfrocket's Avatar
Default timing chain tensioners
Rebuilt 4.2 2003 s type motor was brought to me in a box so have couple questions re tensioners upon starting after rebuild timing chains were noisy so pulled cover off to check for a visual problem. Discovered the tensioners were not getting any oil pressure have good pressure up to the cams. everything looked good with the oil pump
Old Dec 29, 2014 | 04:56 AM
Since there is no reply as yet, I thought I would add what I know, which is near NOTHING on these V8's, but here goes.
The parts list shows the top chain tensiners are RH and LH?????. Maybe the units are on the wrong head from the rebuild, and are blocking the oil supply hole that is in the camblock?????.
Just my 2cents from way down here.
Old Dec 29, 2014 | 12:55 PM
tbird6's Avatar
That's a tough one because there are very few problems with the 4.2L and certainly none with the tensioners as Jaguar made several design changes that fixed all the 4.0L problems.
Do you have the JTIS? It's free on this forum.
Old Jan 4, 2015 | 02:19 PM
wfrocket's Avatar
No i dont have JITS new to this site, what exactly is JITS Does any one know if there is an oil passage schematic available for the 2003 4.2 motor or have knowledge of how the oil flow from oil pump to tensioners. Trying to make a connection as to why I have oil pressure to cams but not to tensioner. Trying to figure out if cams and tensioners are oiled thru same passage.
Old Jan 4, 2015 | 03:39 PM
JagV8's Avatar
With a Search button or google I could maybe find JTIS if I could spell it...
Old Jan 4, 2015 | 03:56 PM
Gippsland's Avatar
Jaguar Technician Information System (JTIS)
Old Jan 4, 2015 | 06:21 PM
abonano's Avatar
If you seek the information you will find it... (I did notice the OP only has 5 posts and may not have access to downloads yet)
RoyLittle0
May 25, 2023 02:38 AM
Jpav27
Jul 31, 2022 06:43 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
