Timing sprocket torque spec
Old Mar 9, 2024 | 01:17 PM
Mike 8897's Avatar
Default Timing sprocket torque spec
I have a 4.2 Lsupercharged non vvt motor . I rebuilt the motor and now set the timing . The only torque spec I could find in the shop manual was 120 NM and that was for the vvt engine . Before I close up the front cover I wanna make sure the bolts are torqued correctly . Thanks !
Old Mar 9, 2024 | 02:08 PM
motorcarman's Avatar
Check you PM inbox, I answered your message.
A SuperCharged engine should NOT have the bolt with the drilled oil passage.
File Type: pdf
60Gunner
Nov 4, 2021 02:49 PM
Amphigory
Dec 20, 2018 10:51 PM
XxSlowpokexX
Jul 24, 2016 04:22 PM
Bcrary3
Aug 31, 2015 11:29 AM
timsalyer
Jun 26, 2014 09:14 PM
