trans code
Old Oct 19, 2017 | 12:24 PM
Jaguarstype's Avatar
Default trans code
Hay, i was driving my jaguar s type r 2005 just fine for most the day it wasn't shifting hard or anything smooth and good.
i parked it and left for about 1 hour to a 1 hour and 30 minutes and when i get back and try to start my car i get a trans fault code and it wont shift into gear it grabs on and grabs off anyone know why this happened? There is no fluid leaked out and i put new fluid into it before its not to old.
Thanks.
Old Oct 19, 2017 | 01:12 PM
Have you checked the two small bolts that connect the shift cable to the transmission?
See post #5 here https://www.jaguarforums.com/forum/x...ck-park-85682/
Old Oct 19, 2017 | 01:43 PM
JagV8's Avatar
Stating it would give people a chance...
Old Oct 19, 2017 | 03:01 PM
i can shift threw P R N D but i think i might just need to add more fluid in it pops into gear sounds like its grinding then it pops out
Old Oct 20, 2017 | 02:46 AM
cat_as_trophy's Avatar
I trust you are aware that the ZF 6HP26 auto will no be a happy chappy if you hit & miss top up the fluid. There is a quite specific temperature dependent process for setting the fluid level . . . difficult, but not impossible to DIY, but important you do it properly.
Best wishes,
Ken
Old Oct 22, 2017 | 06:22 PM
okay so new fluied made sure its full clean flush let it cycle but its still doing it its not a grind but like a rub a its giving my a trans fault code is there any way i can see what code its giving me? i can drive it but on acceleration it rubs its almost like it pops out and into gear.
Old Oct 27, 2017 | 11:27 PM
BlackKat's Avatar
Check plugs and coils. Had a very similar issue that was caused by this. The jag is not good at giving misfire codes.
Old Nov 4, 2017 | 03:29 AM
That's good advice from BlackKat, because he is stating a well known issue whereby plug misfires (?oiled plug holes) can mimic exactly your symptoms . . . as can a variety of other issues!
So, can I refer you back to the earlier post by [JagV8] that says it all - you simply must get the codes read (our understanding is that Autozone or similar in your area will do it for free) and post the actual codes here - not any interpretations please.
Without that info, parlour guessing games of all possible options, are really great fun - but quickly become frustrating for everyone - and potentially expensive for you.
Best wishes,
Ken
Old Nov 7, 2017 | 11:01 PM
The codes i got
p0730
p0825
p0736
p0735
any help?
Old Nov 8, 2017 | 04:57 AM
JagV8's Avatar
Result of post #2?
Details of codes are in JTIS (free download) / code PDF (free) / Gus's site (free).
Old Nov 8, 2017 | 06:15 AM
Hopefully! Well worth 5 mins to check.
You can see the bolts in one of the videos here https://www.jaguarforums.com/forum/s...age-faq-45959/
Old Nov 19, 2017 | 04:33 PM
okay so i rest my computer and drove got new codes misfire cylinder 4 misfire and 6 misfire. and injector circuit
this is different code reader
p1 316/$11 injector
p0 306/$11 misfire
p0 304/$11 misfire
you guys think its the injectors? because of the codes?
Old Nov 19, 2017 | 05:19 PM
JagV8's Avatar
Wrong meaning of P1316. It's a severe misfire doing cat damage.
(If all else fails, download the info for free.)
Usually bad coils.
Misfires (or other engine codes) sometimes upset the trans.
Have a read on what others did with those codes. Drop the weird space in them (and the $11 which is the PCM's address - who cares...).
Old Nov 24, 2017 | 12:41 AM
Alright ill change my coils i feel like thats it ill get back to you guys!
