Trans Fluid ? Type How to check it?
Old May 17, 2008 | 09:33 AM
FactoryJaguarTech's Avatar
Default RE: Trans Fluid ? Type How to check it?
Bring it to the specified temp on he rear of trans. You then remove the torx screew in middle of drain plug on bottom of trans. Do not remove the drain plug. It should trickle out of the torx screw hole.
Old May 17, 2008 | 08:28 PM
ohsigmachi's Avatar
Mercon V and there is a fill plug on the rear upper passengers side of the trans case.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Steve Langridge
Sep 3, 2015 07:35 PM
mrplow58
Aug 29, 2015 10:44 PM
dpappyp
Aug 27, 2015 06:31 AM
