transmission
Old Oct 21, 2015 | 03:04 AM
geff's Avatar
Default transmission
Hello there can anyone tell me what gearbox i have as i have heared that the ZF had problems i have a 2002 SE Stype thank you
Old Oct 21, 2015 | 04:01 AM
JagV8's Avatar
"I have heard" - just ignore that. The ZF is in many cars including Audi, BMW, Bentley.
Is your VIN before or after M45254?
Old Oct 25, 2015 | 11:45 PM
geff's Avatar
hi the vin on my car is M71813 so not sure what that means can you help thank you
Old Oct 25, 2015 | 11:50 PM
geff's Avatar
I also have two other problems one is that i am loosing coolant have replaced the thermostat and no signs of leaks, and no signs of it contaminating with the engine oil yet it will loose approx 1 Litre of water within a 50klms zone and i get a shudder when i doing around 60klms sounds like its coming from the rear can anyone help the Jag I have is a 2002 S type thank you
Old Oct 26, 2015 | 03:02 AM
JagV8's Avatar
That VIN shows you have the ZF 6HP26, if auto.
Hunt down the leak. It leaves a red stain so tends to be quite easy except on the STR which is crammed in the engine bay.
Old Oct 26, 2015 | 03:29 AM
geff's Avatar
Thank you have tried to check for any stains but no luck will keep trying could i have the lurch happening as the car seems to want to go erratic when traveling around the 60 klm`s hope you can hel thank you
Old Oct 26, 2015 | 03:30 AM
geff's Avatar
Catsgame
Oct 21, 2015 08:46 AM
Cody04XJ8
Oct 18, 2015 05:19 PM
nurquhar
Oct 17, 2015 06:41 AM
JimC64
Oct 13, 2015 07:08 PM
jessejamestw23
Sep 26, 2015 03:57 PM
