transmission
Old Feb 27, 2008 | 03:18 PM
aquill1's Avatar
Default RE: transmission
Welcome...hmm those problems can be very irritating. Hopefully someone chimes in soon that could actually help you...
Old Feb 27, 2008 | 05:11 PM
jag_genius's Avatar
well jag didn't change the trani fluid.. all uses expensive mineral oil.. and there is specific software for certain problems that have to be downloaded into your car..or mayneed newvalve body.but however when programming cars.. the shift adaptation.. is cleared.. and it takes time for the trani to shift to your driving habits..
Old Feb 27, 2008 | 05:44 PM
jag_genius's Avatar
umm no but checking the level wud be nice. but a valve body is $3k so i wud go thru the software part first.. the tech wud have to start the programming and then wud have to call the headquaters and ask for a specific problem software .. and the techline will give him a specific code to enter into the computer. then the specific software gets down loaded.. if the software doesnt fix it then it wud need a valve body of a whole trani.
Old Feb 27, 2008 | 09:06 PM
FactoryJaguarTech's Avatar
maybe fluid low. New software comes out all the time. I would get adaptions cleared and update done. Also get level checked.
Old Feb 27, 2008 | 10:30 PM
badmojo's Avatar
My trans. does the same thing when coming to a stop it feels like it's downshifting into 1st late. I was told that it could be a software issue but I haven't had it updated yet. Hard reset did not do any good. I understand that this is pretty common. Still it's not right.
Old Feb 28, 2008 | 09:34 AM
badmojo's Avatar
I was told that software updates are not covered by SE. So I was told to drive it for awhile after clearing the fault codes and then bring it back in. Software updates will cost me 250.00.
P.S. I also occasionally have the car give a couple of jerks AFTER I am completely stopped.
Old Feb 28, 2008 | 07:28 PM
ECM and TCM software updates are covered by Select Edition. No other software updates are though. Fuel injector cleaning is not covered by select.
BadMojo, I would call around and ask. But for sure we do ECM and TCM under select. Just make sure when they do the TCM that they also clear adaptions and perform the drive cycle. There should be a few miles put on the car to do the drive cycle. I can also give you the TSB that tells you how to do it so you can do it yourself also.
Old Feb 28, 2008 | 07:32 PM
jag_genius's Avatar
covered up here.
Old Feb 29, 2008 | 09:50 AM
styper526's Avatar
hey guys lots of good info here. i feel the same thing alot when coming to a stop. is this the "lurch" that so many people have talked about? there is a site dedicated to it im sure you have been to/ had some involvement with http://thelurch.com/. is this something i should be concerned about? any damage known? myS.E. is out in aug. and i would hate to be ignoring a problem.
Old Feb 29, 2008 | 12:33 PM
badmojo's Avatar
I just made an appointment with the dealer and they told me that reprogramming of the TCU is not covered by SE. Even if it is the cause of issues with the trans. it is not covered. I have the drive cycle but thanks anyway.
Just to confirm, I called SE and was told that reprogramming is not covered because it is considered a maintainance item.
Feel free to call customer service and ask about this and let us know what they say!!
Old Mar 1, 2008 | 07:16 PM
Unbelievable. I just don't understand how things get covered, not covered.
Next time you in FL mojo stop by and I will flash it for you.
Old Mar 2, 2008 | 09:53 AM
jag_genius's Avatar
or in canada i will do the same lol
Old Mar 2, 2008 | 12:57 PM
Maybe we should get financed and open our own dealer eh Genius?
Old Mar 2, 2008 | 04:52 PM
badmojo's Avatar
Thanks for the offer guy's. Maybe your dealers are not listng it is a reflash and thats how it is getting covered.
P.S. I think Canada is closer. LOL
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
