Transmission cooling line repair
Old Dec 21, 2019 | 02:10 AM
twinsemi's Avatar
As to the part number for the adapter, that would be:
Russell 639233
#8 AN male to 1/2" tube compression
Old Dec 21, 2019 | 08:41 AM
Reklaw1973's Avatar
Many thanks to Smeghead for the great write up, and to all of you who took the time to reply and offer advice.
Transmission cooling line repaired thanks to the advice from all of you. The fittings shown by Smeghead fit the lines perfectly, and now we have part numbers and many who have succeeded to offer help to others in the future.
I dig this forum, makes the seemingly impossible, possible.
You guys rock!
Old Dec 24, 2019 | 01:03 AM
Aarcuda's Avatar
So im curious why you couldnt just cut the crimping ring off both sides of the rubber section and the add in a new section of 1/2” tranny line and some clamps?
worst case scenarios you might have to flare the end of the tubes to hold the hose on but normally those end pieces are notched for grip
Old Dec 24, 2019 | 02:22 PM
scottjh9's Avatar
You can....that is what i did....you still have to cut the line in two to get it out to work with it and then use a compression fitting to splice back together.....either way the line gets cut and spliced
Old Dec 27, 2019 | 09:18 AM
Smeghead's Avatar
There is more than one way to skin a cat. Clamping or crimping a new section of hose in is one of them. Earlier this year I found transmission fluid leaking and feared my splice was leaking. I found instead that the other trans cooling line was leaking . This time I replaced the entire line without splicing as I had already had the part and was changing the air conditioning compressor (second story for another time) which made it possible to install the complete line.
However you do it learn from my mistake and replace both flexible portions.
Old Dec 27, 2019 | 10:38 AM
scottjh9's Avatar
Excellent.....i was wondering if compressor removal would make room for the entire line to be removed....i looked at that option before my repair, but was not sure.....if i have any future troubles that will be the ticket
Old Dec 29, 2019 | 11:03 AM
Aarcuda's Avatar
Heres my repair. Love these band clamps!
original cooling line crimps leaking
Disconnect lines from radiator and pull down from under car to get to crimps
Once the lines are down you cut off old crimp w dremel and replace rubber lines
Changing trans fluid. Used Pantosin ATF-1 Took 7 quarts to refill
This skinny oring threw me off for twi days. Its not right. Its actually a shaved off portion of a previously installed oring. This line leaked at the fitting to radiator
Correct oring
These two *******s confused me. These are not the right irings
Repaired lines
DONE
Old Dec 29, 2019 | 12:02 PM
  #28
abonano's Avatar
Dup post
Awesome job. Did you replace the rubber lines or did you use the original ones?
Old Dec 30, 2019 | 07:26 AM
Aarcuda's Avatar
I bought new 1/2" transmission line and cut it to fit (made it slightly longer for strain relief.
I really love these clamps! No chance they'll leak!
Old Dec 30, 2019 | 07:50 AM
  #30
abonano's Avatar
Your set up looks tight. Do you have a link for those clamps.
I'm sure you need a tool for them as well.
My lines look good (at this point - surprisingly) as I had to change out my oil pan gasket.
At some point I'll have to tackle this. Funny thing is I have a new set of trans lines I purchased for my previous X350 but traded it in.
I'm definitely going your route for sure. One and done.
Old Dec 30, 2019 | 10:47 AM
  #31
Aarcuda's Avatar
Got this kit from amazon with the tool
Amazon Amazon
Old Jul 16, 2021 | 09:45 PM
  #32
xalty's Avatar
all these methods require effort skill and patience.
get a tubing cutter and cut the line, it doesn’t even need to be straight. now slather the line in high tack sealant, slip your hose on double clamp and you’re done. it’s not coming off period end of story
Old Jul 21, 2021 | 11:16 AM
  #33
Aarcuda's Avatar
NO!!! I did this on my cuda thinking itll work. The line pressure and lubrication from the tranny fluid popped the line off at 5500 rpm midway down the quarter mile leaving fluid all over the track.
FLARE THE ENDS OF THE LINE!!
Old Jul 21, 2021 | 12:08 PM
  #34
xalty's Avatar
try pulling mine off, the rubber is welded to the pipe. the only way you’re getting it off is cutting it.
cutting the crimp and using the factory flare is still the better method for sure.
Old Jul 21, 2021 | 01:50 PM
  #35
scottjh9's Avatar
Yeah that hi tack is good stuff. Once it sets it is there forever. Especially rubber or gasket material to metal
Old Feb 14, 2022 | 07:25 AM
  #36
elDariusVargas's Avatar
Correct
Repaired lines
DONE
Hi
Im about to do the same method on mine.
any updates?
Did their exterior resist to the heat and vapors?
i have trust issues due to hoses exterior cracking on me...
what pressure do they have to withstand to?
what temperature resistance? I know the coolant is around 105 celsius
actually what brand and spec of hose did you use? Many thanks
if anyone else has positive experience with theirs, please let me know
Old Feb 14, 2022 | 08:06 AM
  #37
xalty's Avatar
Originally Posted by elDariusVargas
Hi
any updates?
use gates brand
Old Feb 14, 2022 | 02:29 PM
  #38
thank you. i will wait in hopes that someone can point me to the needed technical specs
Old Feb 14, 2022 | 02:58 PM
  #39
xalty's Avatar
Amazon Amazon
Old Feb 15, 2022 | 06:27 AM
  #40
many thanks.
so i shouldn't worry about any external cracks due to oil/vapors/temp?
i have trust issues because i'll show what happened to this GAS hose that i used for the gas return, due to european cr*p standards.
from my experience if its not american, english or japanese, i should keep away from it!!!!
with all respect, look at this german quality... just look: its been used 2 months, no exterior contact with petrolium products!!! i should send it back to germany so they can take a quality look to inspect it to see how large these .... forget it.
Sorry im mad, i could have been set on fire by this fake hose. i just dont want the trans hose to blow up like this was about to.
