Transmission cooling line repair
Old Feb 15, 2022 | 05:32 PM
  #41
Aarcuda's Avatar
Originally Posted by elDariusVargas
Hi
Im about to do the same method on mine.
any updates?
Did their exterior resist to the heat and vapors?
i have trust issues due to hoses exterior cracking on me...
what pressure do they have to withstand to?
what temperature resistance? I know the coolant is around 105 celsius
actually what brand and spec of hose did you use? Many thanks
if anyone else has positive experience with theirs, please let me know
I just re-used the original hose with last inches so cut off. Rest of the hose is fine. And it hasn’t leaked so far so I think my fix is OK
Old Feb 16, 2022 | 07:15 AM
  #42
elDariusVargas's Avatar
Originally Posted by Aarcuda
I bought new 1/2" transmission line and cut it to fit (made it slightly longer for strain relief.
I really love these clamps! No chance they'll leak!
Thank for the reply!
What so have you changed those two hoses? as they look different
Old Mar 18, 2022 | 01:39 PM
  #43
hi im back!
maybe i have the easiest solution:
Thanks mr hemi cuda for giving me the best idea, to keep the stock hoses.
I just took some 20-22mm power hose clamps and some cloth tape and tighten the stock fittings.
(i used one wrap of tape under each clamp to make sure it grips and doesnt pinch)
i just had to drain the coolant and tanke the radi hose out to acces the trans lines.
no leaks detected after this fix
still dry after 1 month.
the only drawback is that they are not spinning fittings anymore. i couldn't care less. even easier to remember their tightening position.
Old Mar 22, 2022 | 11:24 AM
  #44
Aarcuda's Avatar
hi im back!
looks good. I bet itll work.
Old Mar 22, 2022 | 01:03 PM
  #45
clubairth1's Avatar
Community Influencer
I like to remove the factory crimped connection (cut it off with my Dremel tool) and clean everything up before reassembling. I also recommend using 2 hose clamps and have them placed in opposite directions.
I also reused the factory rubber hoses but others have replaced the rubber hose as well. After my repair it never leaked again while I owned the car.
megacattin
26
Mar 17, 2025 07:54 AM
Jon89
Feb 22, 2018 01:12 PM
KidRock'n
Jul 2, 2017 10:50 PM
euphonium01
Nov 4, 2016 07:18 PM
JagCrank
May 12, 2013 09:27 PM
