Transmission woes and replacement
Old Mar 13, 2024 | 04:50 PM
all2many's Avatar
Default Transmission woes and replacement
o3 type s r is for sale by me but has trans fault tcm seems to be problem can find used trans wonder if a swap will make right without any programing
Old Mar 13, 2024 | 09:14 PM
Mike 8897's Avatar
Hi , I own a 03 str . I had gearbox fault . Many times the issue with the trans is pressure loss. I rebuilt my valvebody with sonnax zip kit . I replaced the bridge seal and 4 tube seals. The transmission shifts better than when I bought it new. These transmissions are sensitive to pressure and fluid changes . I'd recommend doing the service before replacing it . The zip kit was less than 200 $ and the trans oil and pan filter was inexpensive as well. You could do the whole service in a day . Hope this helps. You'll have to identify which gen zf trans you have . The way to do it is when you drop the valvebody there will be a code on a tab . Mine was #036 which meant it was a gen 1 transmission. I ordered the kit and a new seperator plate as well. Good luck
Old Mar 14, 2024 | 06:58 AM
JagV8's Avatar
Could be a fake code (low battery) or the trans/shifter bolt(s) loose/absent.
Old Mar 14, 2024 | 11:19 AM
all2many's Avatar
Thanks will give it a go
edadoune
Feb 14, 2018 06:48 PM
metalmarty
Nov 3, 2014 06:42 PM
2jag
Feb 5, 2013 04:23 PM
heima
Nov 15, 2012 10:40 PM
