Valvoline ATF for Jags, all years and models.
Old May 7, 2017 | 07:44 PM
car5car's Avatar
Default Valvoline ATF for Jags, all years and models.
I use MaxLife ATF for almost all cars according to Valvoline.
Used it for Mercedes and my Jaguar. $20-25/ga
Attached Thumbnails Valvoline ATF for Jags, all years and models.-jag-valvoline-atf.jpg
Old May 9, 2017 | 05:05 AM
JagV8's Avatar
I don't see any way it can meet those incompatible specs...
Old May 9, 2017 | 05:18 AM
Just looked at the Valvoline Guide, and MaxLife Full Synthetic specs do not include ZF Longlife etc.
Maybe OK for the 5 speeds and 4 speeds of old, but not the 6 and 8 speed units.
Old May 9, 2017 | 07:03 AM
Jon89's Avatar
I believe that Mercon SP continues to be the safest aftermarket ATF bet for any ZF 6HP26 unit. I remain very happy with its performance in both of our Jaguars....
Old May 9, 2017 | 11:55 AM
clubairth1's Avatar
Community Influencer
Another vote for Mercon SP. It's cheap and is known to work. No point in using Valvoline.
I used Lifeguard6 the first time but if I do another change it will be with Mercon SP.
Old May 9, 2017 | 02:08 PM
TonyX's Avatar
Another vote for Mercon SP having used it last 5 years.
Old May 9, 2017 | 11:05 PM
jagstuart's Avatar
Found this on my old bimmer forum:
Mercon SP Fluid is a newer transmission fluid made by shell for Ford dealers. Its easy to find online, and it retails for around $4:00+/quart. Things get really interesting when you look at the specs of lifeguard 6 found in the MSDS:
http://www.tsgparts.net/images/pdf/Lifeguardfluid6.pdf and compare them to the specs of Mercon SP:
http://www.fcsdchemicalsandlubricant...ERCON%20SP.pdf and http://www.fcsdchemicalsandlubricant...us175325us.pdf
VERY similar specs, and the same color fluid.
