voice command issues. 2005 s-type
Old Jan 25, 2012 | 11:46 AM
S-taurean's Avatar
Default voice command issues. 2005 s-type
just bought a used 2005 s-type. i am having problems with the voice command. when i have the music on and hit the voice command button all it does is mute the music. there is no beep to let me know that it is ready for my commands. another question i have is this car equiped with bluetooth?
Old Jan 25, 2012 | 12:58 PM
police666's Avatar
It sounds like you don't have voice command. does it work with the music off ?
Old Jan 25, 2012 | 01:09 PM
MarcTheShark's Avatar
Ditto, if all you get is mute, then you do not have that option.
Old Jan 25, 2012 | 06:21 PM
S-taurean's Avatar
Thanks for the reply to the both of you. Is that an option that I can be installed, and would I have to replace my navigation system to have it installed? I would think that if it was equipped a navigation system that it would also have voice command. Shows how much I know
Old Jan 25, 2012 | 06:24 PM
S-taurean's Avatar
and that would be a no to police666. i dont hear the beep or nothing like that.
Old Jan 26, 2012 | 02:34 AM
JagV8's Avatar
It will output voice if not set to be quiet (*). JaguarVoice is where the car inputs i.e. you issue commands. As above, unlikely you have it but why not email Jaguar Corp and ask for full info on your car.
(*) read the manual
free to download........
Old Jan 26, 2012 | 05:44 AM
police666's Avatar
i emailed jag and got a reply the next day with everything my car had fitted to it, even the type annd color of the wood !!!!!
if the button does nothing when no music you don't have voice, i think you might be able to install the voice module but not 100% sure, someone on here will know for sure
Old Jan 26, 2012 | 09:56 AM
xjrguy's Avatar
First, if you had Voice control when the button is pressed, the S-Type will show the message "Listening" in the Message Center of the instruments.
Second, yes, you can add Voice, it's just a salty proposition. The attached bulletin lists what is needed.
Cheers,
File Type: pdf
Old Jan 26, 2012 | 10:05 AM
Michael Star's Avatar
Huh what? You could get them with voice control? Anyone know what the costs would be to retrofit this?
Old Jan 26, 2012 | 10:23 AM
clubairth1's Avatar
Community Influencer
I wanted to add this and blue tooth to my 2005 STR. Could not find used modules and it's just too expensive from Jaguar. I settled for the ACM and love the USB music!!
Old Jan 26, 2012 | 10:25 AM
JagV8's Avatar
Anyone interested can Search on JaguarVoice (possibly just voice but that won't match) for previous threads. Yes you can retrofit, no you don't lose your nav (why on earth would you???).
Old Jan 28, 2012 | 02:40 PM
Toller's Avatar
As I recall, adding JaguarVoice to my 2005 S-type 3 cost about $700. It takes a module and a cable. It doesn't disable the Nav unit. All this stuff is on a local area network and the JagVoice unit is just one more "subscriber" on the LAN.
Biggest difficulty I have is remembering all the commands. My wife drives the Jag everyday so when I drive it there's a lot to learn all over. The module helps. Press the button and say, "Help" and it will provide a "top-down" explanation of the commands.
Old Jan 29, 2012 | 09:16 AM
JagV8's Avatar
And the handbook is available for free download as the other handbooks are.
Old Feb 1, 2012 | 12:01 AM
jya's Avatar
jya
I have a brand new voice module and the microphone that is required to upgrade you car. The module is for the US market but should suit other markets. Also I have a new Bluetooth module as well if anyone is looking to upgrade. These modules plug straight in.
Old Feb 1, 2012 | 08:40 AM
Staatsof's Avatar
Cheers,
Thanks for posting this but O U C H!
JAGUAR XR834964 MODULE/VOICE (QTY of 1 Jaguar parts), JAGUAR OEM PARTS
OH this is a bit better but not enough ...
http://www.carpartsestore.com/prodde...?prod=XR849645
Old Feb 1, 2012 | 08:53 AM
xjrguy's Avatar
Originally Posted by Staatsof
Toad Ya!!
Old Mar 12, 2012 | 12:17 PM
Wpbjag's Avatar
Thanks for the info, where would I find this handbook to download?
Old Mar 12, 2012 | 12:30 PM
Wpbjag's Avatar
Thanks for the info, where would I find this handbook to download? the voice activation handbook, I have the other handbooks
Old Mar 12, 2012 | 01:17 PM
xjrguy's Avatar
Can you confirm whether you have Navigation or not, the books would be different.
Cheers,
Old Mar 13, 2012 | 04:20 AM
Wpbjag's Avatar
Cheers,
Yes, I have navigation.
