WATER IN MY TRUNK NEAR THE SPARE TIRE HELP ????
Old Jan 1, 2008 | 07:40 PM
badmojo's Avatar
Default RE: WATER IN MY TRUNK NEAR THE SPARE TIRE HELP ????
I'm not sure how common it is but I think some others have had this too. I would try to see if it's not getting in from underneath or check for wet areas around the trunk seals.
Old Jan 2, 2008 | 07:23 PM
jag_genius's Avatar
s type since 2000 have had there trunks filled with water... even at there ports in halifax... there drain holes were never punched thru.. to drain excess fluid out.. under your car trunk area there will be 8 holes i think punch them all out...
Old Jan 3, 2008 | 11:54 AM
STR's Avatar
STR
I have the same problem. I specially get a lot of water when it rains.
So i decided to see if i can figure it out. I removed every thing form the trunk then
i got the water hose let it run for a couple of minutes and i noticed the the water
was going underneath the trunk seal so removed it added silicone to the lip where the seal
goes and around the bottom of the seal.. I'm still waiting for some rain to so if that was
the main problem.
Old Jan 4, 2008 | 04:26 PM
SilverSType's Avatar
I just had a huge problem with some electrical components in my trunk getting corroded from the exact problem. The ******* said the trunk seal at the base near the bumper was dry-rotted. They also drilled a hole in the trunk so no more water could build up. (So I can't tell if the trunk seal was the actual fix without filling the hole and dowsing it with water.) On my car it really appears that it is leaking at the seam right below the trunk seal at the top of the bumper. (Water creeps down the seam and into the bottom of the trunk never actually leaking onto the carpet.) Seems that the quick fix is to drill a strategically placed hole down there to avoid puddling.
Old Jan 5, 2008 | 06:18 PM
badmojo's Avatar
I checked mine today and I am happy to say that it is bone dry!
Old Jan 6, 2008 | 06:49 PM
12RM's Avatar
No need to punch holes in the boot floor, the problem will be with the boot (trunk) seal itself. Some replace it, some just lift it up and run some sealer along the lip and then replace the seal.
It will be leaking just about where the rear panels join beside the tail light cluster, even if you only apply sealant a few inches above and below thatjoint you'll sort it.
Old Jan 7, 2008 | 10:13 AM
STR's Avatar
STR
So we had rain this weekend and i did not find a drop of water in the trunk..
I guess the silicone worked.
Old Feb 15, 2008 | 11:58 AM
super_jag's Avatar
I just checked my trunk is full of ice about a 1/4 inch I will try the sealant
Old Feb 15, 2008 | 12:47 PM
KAZsam's Avatar
Super_Jag before you fix the leak and get rid of the ice we could
use your car for beer runs lol
Old Feb 15, 2008 | 01:02 PM
super_jag's Avatar
Hell yeah that sounds like a plan... [sm=icon_cheers.gif]
Old Mar 20, 2008 | 01:14 AM
The_Ikon's Avatar
ORIGINAL: frombenz2jag
So I noticed where my spare tire is, that there is water sitting down in the well. Where is this water comming from. My car battery is down there too, so Im concerned. Is this a common problem ? The carpet thats covering the trunk area is not wet, only where the spare tire is. Please help.
On my Type R, the tech at Jag stated it was very common! He replaced the rubber seal AND put sealant underneath it! My car was still under the 50000 warranty.. No coin to me...
Old Mar 20, 2008 | 04:58 AM
FactoryJaguarTech's Avatar
Yep common. Oh how I long for those water babies to come rolling through the door.
Rivguy
Dec 4, 2020 07:55 AM
perfectson
Nov 1, 2015 10:46 AM
smith356
Oct 7, 2015 06:41 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1100me
Sep 7, 2015 06:26 AM
