Water pump bolt torques
Old Mar 13, 2020 | 07:12 PM
ControlIssues's Avatar
Default Water pump bolt torques
2004 3.0 water pump replacement. JTIS has 25Nm for the bolts holding the pump to the block. I need to pair my inlet housing to the new pump. I'm thinking more like 10Nm for those but I'd rather see it as a specification. Anybody know?
Old Mar 13, 2020 | 07:26 PM
Catfan01's Avatar
Is this what you need?
Old Mar 13, 2020 | 08:53 PM
Thanks Catfan, that is where I got the 25Nm for mounting the pump to the engine. The seven bolts holding the housing halves together are much smaller, no way they'll go 25. I'll be using anti-seize on the threads too which adds a need to favor the lighter side even more.
Old Mar 14, 2020 | 09:35 AM
abonano's Avatar
Try 8Nm + 90 degrees. That is the spec for the V8 engines. That should be less than 24Nm but get you into the neighborhood, especially with anti seize. (Smart move on the antiseize - I did that myself)
Now in my case I got 8Nm + 45 to 60 degrees of rotation and stopped as I didnt want to snap any bolts.
Hope this is helpful!
Old Mar 14, 2020 | 11:30 AM
I think it sounds good. Appreciate the feedback.
Old Mar 14, 2020 | 01:53 PM
abonano's Avatar
Anytime. BTW, no leaks from my water pump even though I didn't get to that +90 deg mark.
Patterson
Apr 13, 2014 09:00 PM
04xtype04
Apr 13, 2014 04:29 PM
socalXJ8
Mar 22, 2014 05:11 AM
Doug
Oct 29, 2012 09:55 AM
