water pump and thermostat replacement
Old Mar 11, 2015 | 10:00 PM
seagates5's Avatar
Default water pump and thermostat replacement
Im working on the timing chain and tensioners and I was wondering should I change the water pump and thermostat also? Its has 180k on the odometer
Old Mar 11, 2015 | 10:15 PM
Jimmy 68's Avatar
If it were me, I would, at that mileage, especially while you're doing the other work.
I'd change the accessory belt, too.
Old Mar 12, 2015 | 04:15 AM
Warspite's Avatar
Yes to both! The original thermostat inlet is plastic, as are the water pump impeller blades, if I'm not mistaken. Just like the tensioners, newer generation replacements are actually better designed. New hoses and belt as well - which would hold true for ANY car!
Old Mar 12, 2015 | 04:31 AM
JagV8's Avatar
Depends on model - unstated by OP! - some are metal.
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
