What type of power steering fluid to use in a 02 s-type 3.0?
Old Oct 14, 2012 | 05:10 PM
daboss085's Avatar
Default What type of power steering fluid to use in a 02 s-type 3.0?
Can anyone tell me what kind of power steering fluid should be used in a 2002 stype v6? Wanted to do a flush and make sure I am using the correct one. thank you
Old Oct 14, 2012 | 06:57 PM
police666's Avatar
taken from jtis
Power assisted steering fluid ESSO DEXRON 2E
Power steering fluid Dextron 3
Old Oct 14, 2012 | 08:31 PM
abonano's Avatar
To translate - Dexron III ATF fluid (or newer since there is now Dexron VI available)
Old Oct 15, 2012 | 01:20 AM
I run Synthetic ATF (Multi vehicle) is our 01 S 3.0ltr, no concerns.
Not knowing what was in there, or how long it had been there, I syringed half the container, refilled with fresh, ran it for a day, did it again, and so on until what came out was the same colour etc as what was going in.
I just have this real "thing" about fresh fluid in a "flush" situation can "shock" some hydraulic systems, and they go legs up, and so does the wallet, so slowly does it has worked for me for a good many years.
Old May 28, 2014 | 08:08 AM
Amadauss's Avatar
Having issues with leak of power steering. Putting Prestone fluid in and that is probably a big no no. Reading this thread, I need to clarify on what is suggested. Hope this does not sound dumb and probably does but ATF? That has always stood for Automatic Transmission fluid for me. So Dexron III ATF power steering fluid correct, not trans fluid?
Old May 28, 2014 | 09:13 AM
NO.
ATF is Automatic Transmission Fluid, and is used in many, many power steer systems, and many manual transmissions also (Ford, Toyota to name 2)
Different markets/languages/etc get the meaning of the product confused.
The aoutomatic transmission is basicallly a hydraulic unit, driven by fluid. The power steer system is the same.
The early S Types have a Ford rack, different fluid, and the later, somewhere in 2001 they switched to a ZF rack for the rest of the model.
The Ford rack requires special fluid, and is a PAIN to bleed. The ZF uses the ATF and self bleeds.
I run Synthetic ATF, as I said earlier.
Old May 28, 2014 | 09:56 PM
motorcarman's Avatar
Grant is correct that the early S-Types use a Ford rack and ESSO 998 fluid.
The 2001> Models were fitted with ZF and Jaguar parts dept stocked MOBIL PREMIUM DEXRON ATF (about $20/QT.) for all the ZF racks.
bob gauff
stanjag
Dec 29, 2024 08:26 PM
rusty37
Jun 7, 2016 04:43 PM
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
dpappyp
Aug 27, 2015 06:31 AM
mkrion
Aug 26, 2015 11:43 AM
