Wheel Wobble
Old Apr 26, 2013 | 02:45 PM
proyal36's Avatar
Default Wheel Wobble
I swapped a bunch of suspension parts on my 2k s-type, including Up&dwn ball joints, Struts & bushings along with sway bar bushings & tie rods a couple of yrs ago and only added about 7k miles since. A month ago, I started getting this terrible wobble in the steering wheel when going over small hills (fishtailing).
My mechanic told me to replace my rack & pinion and they did. But still got the wobble soon after & my right lower ball joint kept getting loose. Now I'm told the ball joint hole in the lower control arm is too big to stay tight.
Does this make sense & can anyone point me where I can get a metal sleeve to take up the slack in the control arm? Thanks.
Old May 2, 2013 | 09:29 AM
matty427's Avatar
Since you haven't received any answers to your question, my humble and not so expert advice would be to firstly make sure that you have really diagnosed the problem correctly. Then I would bring either the C. arm, or maybe even the car to a machine shop and and get them to try to properly fit the thing. Failing that, get another control arm.
Old May 2, 2013 | 09:51 AM
Michael Star's Avatar
Have you checked the tires? I had a car that had a really strange wobble that turned out to be the metal in the tires separating. The tread looked fine, but on a balance machine it was all out of wack.
Old May 2, 2013 | 10:35 AM
Jon89's Avatar
Agreed. Start with the tires. Interior belt separation can play havoc. Look for tread separation as well....
Old May 2, 2013 | 06:09 PM
QuartzSTypeR's Avatar
If the hole is wallowed out, then I wouldn't mess around with it and just replace the ball joint and the control arm since it won't stay tight.
Old May 6, 2013 | 04:40 PM
StypeRowner's Avatar
Default Bent wheel???
Don't ignore the possibility of a bent wheel. I had a previously well regarded
shop balance a wheel that was bent!! Needless to say, i won't deal with them anymore.
Good Luck!!
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Oct 10, 2015 09:33 AM
Roland M
XJ40 ( XJ81 )
Sep 12, 2015 02:25 PM
innzane
Sep 2, 2015 10:08 AM
