When to replace Akebono brake pads?
Old Jul 9, 2017 | 10:14 AM
Staatsof's Avatar
Default When to replace Akebono brake pads?
There is this thread out there already and that's same MY and model car as mine.
https://www.jaguarforums.com/forum/s...ke-job-167137/
Last year I checked about this time and it seems that my pads are still at about 40 - 45% of the original thickness. I don't drive the car in the winter I put them on at about 14-15K miles and I have 62K miles now.
Rotors are smooth like new with a bit of lip of course and not near min thickness.
At what percentage of pad left do folks think these pads should be replaced?
Rears are about 5% more worn than the fronts.
I'm flushing the fluid today.
Thanks.
Old Jul 9, 2017 | 10:31 AM
JagV8's Avatar
Workshop manual (free download) has details - you measure their thickness...
Old Jul 10, 2017 | 03:35 AM
Staatsof's Avatar
I wanted brand specific advice from someone who's used these pads about what to expect.
Old Jul 10, 2017 | 09:35 AM
Mikey's Avatar
Given how much material you've got left and the amount you drive, it sounds like you've got years still to go.
There's nothing to gain by replacing pads early- performance does not decline through usage. The trick is not letting them get too thin and destroying a rotor. No one can guess when that exact moment will be as it varies from driver to driver.
Old Jul 10, 2017 | 10:43 AM
Lspc's Avatar
Took my Akebono's down to about 4mm before replacing with no noticeable difference in braking performance, superb pads and no dust !!
Old Jul 10, 2017 | 02:39 PM
Staatsof's Avatar
I'll try and measure them but getting a set of calipers inside of a caliper () with the shoes in place might be tough. Eyeball guess is 7-8 mm.
Old Jul 10, 2017 | 03:09 PM
JagV8's Avatar
Usual figure is if they're under 3mm when you check then replace them.
At anything like 7-8mm they're fine for a year at least (for ordinary drivers not doing stellar distances) - and I'm sure you check them more often than that.
Generally makes no odds who made them.
Old Jul 11, 2017 | 12:18 AM
Lspc's Avatar
Easier and quicker to take a pad out and measure (imho) easiest pads i've ever changed.
Old Jul 11, 2017 | 09:20 AM
clubairth1's Avatar
Community Influencer
Don't know as mine have over 80K on them and are still good!
Hard to believe as I use the brakes hard. Plus I run slotted rotors which are suppose to shear more pad off than smooth rotors.
Very pleased with AkeBono pads.
