Where can i get an engine for a good price?
Old May 20, 2015 | 04:59 PM
Grote_17's Avatar
Default Where can i get an engine for a good price?
I am looking for an engine for my 2001 S-Type 4.0, Does anybody know where i could find one or any good sites to visit?
Old May 20, 2015 | 05:07 PM
tbird6's Avatar
All of them need the Timmking chain tensioners replaced. Not a cheap or easy job.
I would move on to the 2003 and up S Types. The 4.0L had too many problems.
Old May 20, 2015 | 08:41 PM
joycesjag's Avatar
Car-Part.com--Used Auto Parts Market is a searchable database of wrecking yards.
Old May 20, 2015 | 09:00 PM
Razorback31's Avatar
I use car-part alot. My friend found a 2002 325i motor with 42k miles on it for less than 1500 shipped from florida. Forget site..
Old May 20, 2015 | 09:50 PM
NBCat's Avatar
Here is an AJ28 currently listed on eBay:
http://www.ebay.com/itm/00-01-Jaguar...c4b2f&vxp=mtr:
Old May 20, 2015 | 11:11 PM
I forgot about lkq try to find a local branch and get one from them when I was looking for a seat they were very helpful
Old May 21, 2015 | 04:28 PM
Tijoe's Avatar
Good 4.0 engine are becoming far and few between.
Typically you get what you pay for when you purchase a used engine. The lower the mileage the more you pay. The higher the mileage you pay less, but the greater the risk is will break and waste all your time and money putting it in. I personally wouldn't purchase an engine with over 80K miles on it unless I was planning on some sort of a rebuild. As others have posted, the 4.0 engines had lots of problems. Mainly the timing chain head tensioners. It is also very difficult to get any maintenance history for the engine. Was the oil changed, were all the required services done? Either you luck out, or find out a year or 2 later, you purchased a lemon engine.
I purchased a 2003 STR engine off of E-bay a month ago with 75K miles on it. I have already spent over $1K on replacement parts hoping that the engine wont fail after I put it in. I just hope the engine wasn't ran too hard during its life.
Item Approx cost
- Water pump $50
- Oil pump. $200
- Timing chain kit $450+
- New crankshaft timing gears $200
-Valley/throttle body water hose $40
- Spark plug set $50
- Timing cover Gasket $40
- Timing cover crank seal $20
- Head cover gasket $40
- Other water lines $150
- Gates serpentine belt $40
- Oil filter $10
- Mobil Synthetic Oil $40
_____
Not on your engine, but on Mine
- Super charger oil
- Super charger shout bearings.
Intake manifold and supercharger gaskets.
tonimccloud
19
Jan 18, 2020 01:56 PM
MarathonJohn
Sep 3, 2015 07:59 PM
tonimccloud
Sep 3, 2015 07:58 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Terrance Williams
Aug 26, 2015 11:50 AM
