Where is rear ECM? Does it have to be programmed if I get used?
Old Jan 31, 2016 | 04:11 PM
car5car's Avatar
Default Does ECM have to be programmed if I get used one?
Found it!!!!!!
Does it have to be programmed if I get used one from junk yard?
Old Jan 31, 2016 | 04:46 PM
Datsports's Avatar
If you buy the exact part no# used from same year and model then no !
If buy the exact part no# new then yes !
If you buy one that fits with one or more differant no# in part no# then yes !
Is this the same part no# as yours ?
Old Jan 31, 2016 | 04:48 PM
Datsports's Avatar
What is yours doing rong ?
Old Jan 31, 2016 | 05:32 PM
car5car's Avatar
Thanks!!!
Probably nothing. I am going crazy trying to find battery draw. There are a few fuses drawing current in trunk fuse box. It is hard to diagnose because some modules keep working after key was removed.
I removed rear ECM, it looked rusty, but seemed OK indside.
Old Jan 31, 2016 | 09:43 PM
aholbro1's Avatar
The "Stickies" be your friend: https://www.jaguarforums.com/forum/s...-drain-123535/
Or...you could search eBay for every module ever sold for an S-type and continue replacing parts.
Old Jan 31, 2016 | 10:11 PM
Datsports's Avatar
Set up your multi meter to test for current draw between the earth cable and body utube has some vids on it then Leave the boot open when you see the boot lights go out maybe 15 mins the car is then in sleep mode start pulling fuses to find the draw circuit! Most likely an after market add on to the car , sterio / sub amp or device charger ? I think you'll find those fuses go to sleep when the car does !
Old Feb 1, 2016 | 12:29 AM
car5car's Avatar
Thanks, guys!
I feel better, now I know what to do!
sonny2
May 18, 2016 01:10 PM
64vette
Feb 4, 2016 09:41 AM
PeterG
Feb 4, 2016 08:41 AM
two96jags
Feb 3, 2016 03:44 PM
skullbiker
Jan 31, 2016 02:54 PM
