whistling sound when accelerating
Old Aug 25, 2010 | 07:26 AM
canadajag's Avatar
Default whistling sound when accelerating
Hi guys, just found this forum....have already read some interesting information!
Quick question, I have a 2006 S-Type 3.0L and have recently begun to hear a "whistling" type noise when accelarating. It's not as pronounced when accelerating at low speed but is lounder when accelerating faster. It is faint, almost as if brake calipers are not releasing all the way. Just annoying. Anyone encounter similar? Had rotors and pads replaced about 2 months ago, front and rear.
Old Aug 25, 2010 | 08:04 AM
Jon89's Avatar
Can you definitely pinpoint the source to your wheels? Your issue seems more like a whistling moonroof or mirror housing to me....
Old Aug 25, 2010 | 08:11 AM
Mikey's Avatar
Typically whistling or humming sounds are because the car doesn't yet know the words to the song. This is usually easy to fix with a little ECU self learning.
Seriously, whistling sounds can be from anywhere. Try listening around the engine for a vacuum leak.
Where in Canada are you from?
Old Aug 25, 2010 | 09:10 AM
canadajag's Avatar
it's definetely coming from something related to acceleration, it's tough to pinpoint as it only occurs at a certain accelaration point. I tried monitoring RPM levels when it occurs and have not found a common point. it is not constant, and does not occur when car is idling or once constant speed is attained.
Old Aug 25, 2010 | 10:51 AM
bfsgross's Avatar
May be slipping belts and/or pulleys, as well as failing transmission pump.
Old Aug 25, 2010 | 05:11 PM
jaguar 20's Avatar
i got a 2005 s tyupe 3.0 same prob it was the intake manifold gasket parts are less than 50 bucks but paid dealer 600 to do job i think jon 89 has a write up he did this before on his car
Old Aug 26, 2010 | 06:14 AM
Jon89's Avatar
Nope, it wasn't me since my intake manifold has yet to be removed. I believe it was Rick (joycesjag) who did the intake manifold write-up....
yoiyoi
Dec 19, 2023 12:51 AM
ajacks86
Oct 12, 2017 08:51 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Fmf Doc
Sep 24, 2015 08:28 PM
XFR_Gold
Sep 2, 2015 12:24 PM
