Wood interchange
Old Aug 16, 2020 | 06:24 PM
Cymru67's Avatar
Default Wood interchange
Hello,
Does anyone know it the wood set from a US model VDP 2005 on (Walnut) will fit in a 2003?
TIA
Old Aug 16, 2020 | 11:05 PM
Datsports's Avatar
Do you mean S-type VDP ? If so ,
i have seen the titanium from an 06 s type ,
retrofitted to an 03 . It must be possible.
Old Aug 17, 2020 | 10:18 AM
Cymru67's Avatar
Yes the US edition VDP S-Type that came with the Walnut trim. I know someone with an 03' V8 that want's to switch to Walnut, and was just trying to find out if they are the same--the instrument trim piece in particular. I wasn't sure if the wood design was revised when they switched to the round dials.
Cheers,
Old Aug 17, 2020 | 02:54 PM
Steve M's Avatar
Is there a lot involved in the swap, many things to remove first or just prise off and replace?
Mine is very pale and I would like to walnut it.
Old Aug 17, 2020 | 05:56 PM
joycesjag's Avatar
I have not removed the wood. From what I have read all pieces except for the trim above the glovebox is simple to remove. The piece above the glove fellow member tbird did a DIY how to with pictures AIR. May be he'll see this and chime in.
Guernz
Jan 19, 2016 09:03 PM
windrose
XK120 XK140 XK150
Jun 11, 2015 04:39 PM
Hobbsy
Aug 21, 2013 12:29 AM
DenverDRS
Apr 15, 2013 09:31 PM
H20boy
Aug 12, 2010 11:31 PM
