X-Type Wheels for S-Type
Old Sep 8, 2010 | 07:28 AM
ashmorem's Avatar
Default X-Type Wheels for S-Type
I am about to buy Jag OEM wheels that fitted an X-Type to mount winter tires on. Thes are 17" 108mm x 52mm offset. Please can anyone tell me for sure if these will fit an S-Type? If they will fit do I need alternative lugnuts? Please see attachment.
2006 S-Type 3.0
Old Sep 8, 2010 | 07:57 AM
JOsworth's Avatar
They should fit fine. Do you have OEM wheels on your S? The reason I ask is all the OEM jag wheels have a flat seat for the lugs while aftermarket wheels take a conical lug nut.. So, if you have OEM lugs you are fine...
BTW>> Search here on lug nuts and you will see that the Jaguar factory lugs are really bad and I recommend when you switch wheels change the OEM nuts as well...
Old Sep 8, 2010 | 12:27 PM
ashmorem's Avatar
Thanks for the information.
I thought they may fit as they share the same 108mm x 5 pattern. Yes I do have original Jaguar wheels.
I am looking to get ready for winter and will mount winter tires to the soon to be purchased rims in December. I've found snowfall renders the S-Type virtually unuseable with regular all season tires and hope this is the answer.
H20boy
Dec 24, 2024 03:23 PM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
