X202 V6 Manual Conversion
Old Jul 20, 2013 | 11:09 PM
DeLoached's Avatar
Default X202 V6 Manual Conversion
Hi All,
Just asking if anyone here has been involved in swapping out the ZF 6 spd auto box for a 5 spd manual on their S-Type?
My 6HP24 is working really rough, has had a filter/fluid refresh and software update but all to no avail. Looking at 3.5-4k for a rebuild. 192,000km (120k miles)
Wondering if a manual exchange would work out better? Obviously I need
-Gearbox (will likely have to sea freight from the UK)
-Master cylinder
-Shifter/linkage
-Pedal box
but what else might I need?
-software (new ecu?/standalone?)
-sensors?
Wondering if anyone can shed any light. Don't really want to spend 4 grand on a car that's worth 11 on a good day. Probably looking to sell otherwise. Thanks.
Old Jul 21, 2013 | 07:48 AM
JagV8's Avatar
You mean 6HP26.
Almost impossible to do what you want without a suitable PCM and change all the other modules involved in security, which means not viable.
Be cheaper to swap to another 6HP26 and at least that will work - if you're blaming the right item! But first have you checked very carefully that the engine is 100% right using OBD? The autobox goes crazy if not.
You HAVE changed the battery, right? By far #1 suspect. After that, engine (cheap to check those OBD), and after that the loom behind front bumper.
Cambo
107
Aug 15, 2023 07:30 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Ian Thewlis
Jun 21, 2015 06:51 PM
