from an xjr to an s type, now have a small problem help please
Old Oct 3, 2012 | 05:35 PM
driver safz's Avatar
Default from an xjr to an s type, now have a small problem help please
i have now a jaguar s type 3.0 v6 2004 model, theres a slight nock on the engine and its missfiring on the left hand bank cylinder number 2,4,6 ??? ive changed all coil packs any suggestions thanks
Old Oct 3, 2012 | 05:52 PM
joycesjag's Avatar
safz welcome to the S Type Section.
Suggestions:
-Get codes read
-With having 2, 4 and 6 misfiring, sounds like a vacuum leak for that bank. See below:
https://www.jaguarforums.com/forum/s...ics-faq-52720/
-Knock, hmm lets not hope the worst.
Old Oct 4, 2012 | 08:27 AM
i doubt the nocks that bad it clears on accaleration, ok the codes are
p1314
p0302
p0304
p0306
p3000
Old Oct 4, 2012 | 08:47 AM
JagV8's Avatar
It shouldn't do that. It's faulty and needs fixing as I think you do know
Rick's advice is probably worth taking. You sure look to have a quite bad leak on one bank or possibly a bad cat (careful, it could be on either bank).
Old Oct 4, 2012 | 09:47 AM
bfsgross's Avatar
driversafe, do you hear a rattling sound from underneath the front of car (toasted/worn cats can rattle).
Old Oct 7, 2012 | 05:54 PM
whats your verdict on a decat? will that be an option? thers no vacume leak and i cannot hear any of it sprayed brake cleaner on them changed all coil packs aswell, thanks
Old Oct 7, 2012 | 06:08 PM
bfsgross's Avatar
You can have your exhaust guy cut the pipe just aft of the cats to peek into the cats to see if the honeycomb (catalyst cells) are melted.
Old Oct 8, 2012 | 01:37 AM
JagV8's Avatar
Decat = MoT fail.
stanjag
Dec 29, 2024 08:26 PM
rvdz
Dec 7, 2019 06:42 AM
Paradigm
Jun 15, 2019 05:59 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
