Separate water pump for the transmission?
Quick question. Does the 2009 Jaguar XF Supercharged have a separate water pump for the transmission? came across a post that talk of an auxiliary water pump for transmission or supercharge as stated . And if so how does that work. Thanks peeps
There are two pumps. One is for the heater and one is for the supercharger. You don't have a water pump on the transmission lines.
Here is a thread on swapping the supercharger pump with a larger one to help with cooling: https://www.jaguarforums.com/forum/x...pgrade-152574/
It is applicable to the 2009 XF Supercharged as well. Read through the thread for the other XF owner that swapped it on his 09.
clubairth1
Aug 17, 2017 08:40 AM
