Transmission problem
Received 2,580 Likes
Don B (03-15-2018)
Welcome to the forum Thumprr1226,
I've moved your question from General Tech Help to XJ40 forum. This is the place to post technical questions about your model.
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Received 12,739 Likes
Welcome to the Jaguar Forums!
Is the transmission fault warning lamp illuminated in the instrument cluster? If so, your transmission is in Limp Home Mode (LHM), which locks it in 3rd gear. On our '93, the most common cause of LHM was oil contamination of the electrical connector for the Throttle Position Sensor (TPS). This connector clips to a bracket on the intake manifold elbow just to the left of the throttle body. Separate the two halves and flush them with zero-residue contact cleaner (CRC is a well-known brand). Allow to dry and reconnect.
Regarding the clunk when you put it in Reverse, what is your engine rpm at idle?
Don
The following 4 users liked this post by Don B:
The following 3 users liked this post by Don B:
I don't have a picture of the transmission warning lamp, but your Driver's Handbook/Owner's Manual probably contains an illustration. Basically, the light looks like the outline of a transmission housing, possibly with an X through it, and if I recall correctly, it is on the left edge of the instrument cluster.
The following 2 users liked this post by Don B:
93SB (04-01-2018),
MountainMan (04-01-2018)
93SB (04-01-2018),
93SB (04-01-2018),
