Help with Tire Selection
Old 04-18-2018, 11:09 AM
DonLafferty's Avatar
Default Help with Tire Selection
I have a 2005 XKR that appears to have come with 18" wheels if the sticker on the door is correct. Someone changed them for 20" and installed 285/30 on the rears and 255/30 or 35 (I think) on the front.
I took a long trip last weekend and don't like the ride (too rough) so I'm thinking about getting tires with larger sidewalls but I don't know what would fit.
I know it can/will change the speedometer too but that's less of a concern than the ride.
I could always go back to 18" wheels but would prefer to not have that added expense if a 20" higher profile tire would fit on it.
Any thoughts/ideas would be welcome.
Old 04-18-2018, 12:07 PM
fmertz's Avatar
Received 1,487 Likes on 1,043 Posts
The stock tire/wheel sizes are listed under the armrest for reference. Going out of what is specified will likely not get you where you want to be. You will likely want to change your wheels to something smaller (and fitting your brakes!), and get the corresponding new tires. Assuming the wheels/tires you have are stock and in decent shape, you should be able to sell them for the cost of these smaller wheels. Then the net expense is just your new tires for the smaller wheels.
Have you checked and adjusted your tire pressure? Unlikely to be a huge change, but every bit helps...
Old 04-18-2018, 12:49 PM
Here's what my rims look like. As you can see they aren't stock. I was told they were very expensive when bought but I'm not sure how much I could get out of them. I would be willing to trade straight across for OEM Jag rims.
Old 04-18-2018, 01:10 PM
rothwell's Avatar
Received 1,252 Likes on 687 Posts
I would replace those wheels just on principle. Those are just not right for that car.
Here is a good deal ($650) on a set of 18" Double Fives from an 02 XKR with new-ish Conti Extreme Contact tires.
https://tampa.craigslist.org/hdo/pts...559690088.html
Would look a lot like this
zray (04-18-2018)
Old 04-18-2018, 01:17 PM
Those would be excellent. I sent him a query about what it would cost to ship to me in LA.
Old 04-18-2018, 01:46 PM
fmertz's Avatar
Double check these will fit with the big Brembo brakes...
Old 04-18-2018, 01:57 PM
What's the best way to do that besides trying them?
They came off a 2002 XKR but that doesn't mean it had Brembo (which mine does).
Old 04-18-2018, 02:07 PM
fmertz's Avatar
Exactly, these are wheels that came out for the earlier XKR without the Brembo brakes.
There is a TSB, but it is not definitive:03 XK specs.pdf
Old 04-18-2018, 02:46 PM
toaster's Avatar
Good advice,
with Brembo-brakes they (the Double 5) will not fit (without spacers),
due to rim offset/disk depth.
Old 04-18-2018, 02:53 PM
rothwell's Avatar
Originally Posted by toaster
Good advice,
The Brembo's will fit the 18" radius 'Double 5's' but you will need 15mm spacers on the front.
Old 04-18-2018, 02:57 PM
I wouldn't be adverse to this. I have read you can find spacers on eBay. What do I need to look for?
Old 04-18-2018, 03:02 PM
toaster's Avatar
By the way, same problem with your Apollos
Old 04-18-2018, 03:05 PM
Are you saying my rims are Apollos? I didn't know what they are. If they already have the spacer I wouldn't need one.
Old 04-18-2018, 03:06 PM
toaster's Avatar
Front: https://www.ebay.com/itm/H-R-15MM-WH...dYLe1K&vxp=mtr
Rear: https://www.ebay.com/itm/H-R-25MM-WH...xYLe~e&vxp=mtr
rothwell (04-18-2018)
Old 04-18-2018, 03:10 PM
toaster's Avatar
No, but Rothwells..........
Old 04-18-2018, 03:43 PM
rothwell's Avatar
Yeah my Apollo wheels are not brembo friendly.
That is ok...they still look f-ing awesome even with my humble brakes.
My favorite 19" wheel is Apollo. My favorite 18" wheel is Double Five.
Old 04-18-2018, 04:19 PM
toaster's Avatar
Yes your wheels are f-ing great, brakes are normal, nothing to justify.
The 305 mm discs at my 97er are humble, and then the 17" Revolvers........
I love it!
Old 04-19-2018, 07:05 AM
fmertz's Avatar
Double check you don't already have spacers...
Old 04-19-2018, 07:30 AM
I was wondering about that. When you look at the photo it kind of looks like there might be ones at least on the front. There is a different colored area where the wheel meets the rotor. The rotor is obviously rust colored.
Old 04-20-2018, 03:20 PM
toaster's Avatar
Good advice!
Quick Reply: Help with Tire Selection
