Cranking but won’t start
Old Jan 17, 2022 | 06:17 PM
Donald ThaDon Masson's Avatar
Default Cranking but won’t start
I blew a radiator hose had it towed to the shop where the hose was replaced since it’s been having trouble starting I’ve called 2 mechanic to look at it and when they arrive it starts perfectly. Today a mechanic came twice it started for him he left. I tried, it wouldn’t. He came back it started. We hear the fuel pump. I ran the codes and have p0138 and p0158 with the engine off. Can anyone help
Old Jan 17, 2022 | 06:53 PM
Parker 7's Avatar
Editing complete ....reread added info and ask questions
There are a series of relays you can swap so we will be referencing this Doc
You can double click the image to enlarge and print off at the office supply store from a flash drive
The fuel pump will only come on for 4 seconds only with key rotation and when the crankshaft position sensor sees engine rotation the relay will close for the duration of your drive , You can jumper this relay to directly power the pump at all times , this will drain the battery with the keys in your pocket so plan accordingly
This will be the fwd most socket to the rear most socket , this will be socket 3 to 5 or 30 to 87
Use a blade type connector like this the front counter at a auto parts store can help build up from a tool and parts kit they can dig through
The starter solenoid relay can be swapped with the headlights , fog , or A/C relay of the same part number stamped on it
The ECU gets its 1stpower from the right engine bay fuse box ( called the ignition positive relay ) it can be swapped with the left engine bay fuse box relay which only runs your horn
The ECU gets its 2nd power from the large ECU controlled relay that is controlled by the ECU and brings power back into it , same thing swap with a headlight or other
This 2nd power is needed at all times
The large relays can be stuck so unclip them and flip upside down and spray the mating seam with penetrating oil and a rag to grip them when pulling off the socket
Old Jan 18, 2022 | 01:19 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
A common cause of intermittent cranking but not starting is the crankshaft position sensor. There is usually no fault code raised that directly relates to the sensor itself and they can go intermittently faulty before failing entirely. I have replaced 2 on a low mileage vehicle with genuine Jaguar parts and the first time it was very intermittent. If the tachometer needle moves when cranking then it is likely that the sensor is OK.
Old Jan 18, 2022 | 03:39 PM
Where should the tachometer be when cranking it sits in the zero but shakes even when the car starts
Old Jan 18, 2022 | 05:10 PM
Parker 7's Avatar
The Max cranking speed is 300 RPM\
The CKPS can fail in its use as a fuel pump relay enable without a CEL code of P0335 and the tach still good
If you have the addition of the tach acting up I would put in a new CKPS and are commonly Avail at the auto parts store between $ 90 - 100
CEL P0340 is the Camshaft position sensor that is only used in the starting sequence, but the car will start with the CMPS connector off
The CKPS will be used for ignition timing and fuel injector timing so is a chance that those can fail on the way home
So it depends fs you want to take a chance, but some carry a spare CKPS in their trunk
What you can do for free is to clean the face of the sensor along with the connector
Old Jan 19, 2022 | 02:33 AM
I’m going to replace the crankshaft position sensor, I got it to start and see what you mean by 300 rpm and it wasn’t doing that in the times it didn’t start it would just sit at zero thanks
Old Jan 20, 2022 | 03:53 AM
The sensor should arrive today. I got another code p1193 turned up today. It has been sputtering and cuting off at red lights. Is that all crankshaft position sensor related?
Old Jan 20, 2022 | 08:36 AM
Parker 7's Avatar
Yes but could also be
sticking injectors as the pulse width is at it's shortest at this point
Coil health
under performing fuel pump
out of adjustment TPS , do not touch yet
sticking throttle body butterfly not arriving at the correct idle stop position
throttle cable return spring lacking in force
IAC valve not arriving at the correct position
EGR valve not arriving to the closed position , just cleaning the EGR valve gave someone good idle results
Bad gas at last fill or resent water contamination from the gas cap / clogged fill well drain line , happens more than once , me included
So you would have to pick the easiest without having concrete evidence it is one
New fuel
Your codes are on page 110 for a 95
and page 121 for a 96 - 97
www.jagrepair.com/images/Training Guides/801S - 2000.pdf
Old Yesterday | 11:57 AM
wardhill68's Avatar
97 xj6 ran perfectly sat all winter now just cranks. Tach seems dead. Replaced the cps but still just cranks dead tach . Bad sensor? Thanks
Old Yesterday | 01:00 PM
Parker 7's Avatar
A good sensor will read 1300 ohms as a sensor " basic " reading
The single signal is read by at least 4 things and one may not be good enough as it is discerned by one of them , usually the fuel pump relay enable
The starter enable is from the right engine bay fuse box relay in the corner ( labled ignition positive relay )
The ECU controlled relay ( ECU 2nd power ) may not be clicking closed , this is the power " sitting " on the injectors as the ECU gives the injectors a timed ground wire ( 6 )
CKPS code P0335 but rarely shows from reading others
Old Today | 03:11 PM
wardhill68's Avatar
Can you tell me where the ecu relay is exactly . I will check it’s operation
MattVo29
Sep 3, 2022 09:32 AM
Stamford
Apr 6, 2016 07:37 AM
gapar75
Dec 27, 2014 09:16 PM
Jennell
Dec 31, 2010 06:18 PM
