XF (X260) 2015 onwards
MY2017 XF260 2.0d Prestige BUY OR NOT?
Old Jan 16, 2026 | 03:55 PM
lac1995's Avatar
Lightbulb MY2017 XF260 2.0d Prestige BUY OR NOT?
Hi everyone,
I’m looking for advice from owners/mechanics who know the Jaguar XF X260 20d (Ingenium 2.0 diesel) Australia well.
I’m considering a late 2017 build / MY18 XF 20d Prestige (RWD). It’s single-owner, very low kilometres for its age, appears well kept, and has full service history with no outstanding recall/campaign items per VIN check.
Pre-purchase inspection findings (mobile inspection + scan)
The car drives well and the inspector noted:
  • Smooth running, no obvious knocks/rattles on test drive
  • No timing chain rattle on cold start
  • Suspension bushes visually OK
  • Brake rotors visually OK
  • Minor cosmetic hairline marks only
Main issues identified:
  1. Tyres are ~9 years old (safety risk) → replacement recommended immediately (seller says they’re willing to replace).
  2. Rear brake pads close to replacement (rotors look OK).
  3. Historic fault codes recorded (not active at time of inspection) that appear related to emissions/engine management:
    • Historic NOx / EGR-related entries
    • One historic cooling fan control circuit entry (not active during inspection)
    • Also several historic comms/module-type codes, potentially linked to low-voltage events (scanner showed around ~11.9V during scanning).
DPF snapshot from scan: soot load was around mid-40%, and it showed a regen occurred within the last couple hundred km (so it appears to still be regening, but I don’t know what’s “normal” for this platform).
Inspector suggested: clear codes → do a decent warm drive (mixed/highway) → rescan to confirm nothing returns as current/pending.
What I’m trying to understand (risk vs normal diesel behavior)
I know modern diesels that do lots of short/low-temp running can generate carbon/emissions related warnings over time. I’m trying to determine whether these historic codes are a common “low-use diesel” artifact or a sign that the emissions system is already on the path to becoming expensive.
Questions:
  1. On Ingenium 2.0 diesel, how concerned should I be about historic NOx/EGR/DPF-related codes if there are no active faults right now?
  2. What are the most common “big ticket” issues on 2017–2018 era Ingenium diesels (NOx sensors, EGR valve/cooler, DPF, SCR/AdBlue system, timing chain), and do they show up more with age than with kilometres?
  3. Is a specialist hoist inspection (Jag specialist) worth doing even if the car has good history, specifically to check:
    • underbody leaks,
    • exhaust/DPF/SCR hardware,
    • intake/EGR carbon,
    • engine/gearbox mounts,
    • cooling system / fan operation?
  4. Which live data values would you want to see from a scan to assess emissions health? (e.g., DPF differential pressure, regen counters, NOx sensor readings, EGR commanded vs actual, etc.)
  5. If you were buying one of these out of warranty, what would you budget as a sensible contingency reserve for diesel emissions-related repairs?
Thanks in advance guys. I appreciate the support and knowledge.
Old May 21, 2026 | 10:49 AM
CalebHudson's Avatar
Kuulostaa siltä, että yksilö on yleisesti siisti, mutta nuo Ingenium-dieselit elävät aika paljon ajoprofiilista. Pelkät “historialliset” NOx- ja EGR-koodit ilman aktiivisia vikoja ei vielä ole automaattisesti huono merkki, varsinkin jos auto on tehnyt paljon lyhyttä ajoa tai akkujännite on käynyt alhaalla. Se 11.9V viittaa juuri siihen, että moduulit ovat voineet kirjata satunnaisia häiriöitä.
Old May 21, 2026 | 07:24 PM
Lightweight's Avatar
Default Research before buying
I do not have personal experience of the diesel but they don't have the best reputation. They need oil changes far more frequently than specified and hate short journeys. Oil dilution is a big problem for them.
Mike Fernie is a big Jaguar fan and this is a good overview of the engine
Old May 24, 2026 | 01:54 PM
Kuulostaa aika järkevältä analyysiltä. Nuo Ingenium-dieselit tosiaan tuntuvat olevan aika herkkiä ajoprofiilille, ja lyhyet ajot yhdistettynä matalaan akkujännitteeseen voivat helposti aiheuttaa satunnaisia vikakoodeja ilman, että itse järjestelmässä on varsinaista pysyvää vikaa. Jos koodit ovat vain historiallisia eikä aktiivisia häiriöitä ole, se ei vielä kuulosta kovin huolestuttavalta. 11.9V on kuitenkin sen verran alhainen lukema, että se selittää hyvin nuo satunnaiset EGR- ja NOx-herjat moduuleissa. Roosterbet yhdistää urheiluvedonlyönnin ja kasinopelit https://roosterbet.app/ helppokäyttöiselle alustalle.
Old Yesterday | 10:01 PM
dennis black's Avatar
20 Year Member
No offense to diesel, less problems with Petrol
jschicksps
F-Pace (X761) / C-X17
May 23, 2024 02:54 PM
JagV8
34
Jul 17, 2021 07:30 PM
cat_as_trophy
Diesel variants - All models
25
Dec 28, 2014 04:31 PM
doc
Aug 13, 2014 11:29 AM
PiersWilliams
Jun 9, 2014 05:00 AM
