Stalling issue
Old Apr 21, 2026 | 01:37 PM
IdRatherBeDriving's Avatar
Default Stalling issue
Evening everyone, I've got a 1996 XJ6 Vanden Plas 4.0 that is having a weird issue with dying after idling or driving for a bit. It has new injectors, spark plugs, fuel pump and filter, and I've been swapping out between different ecus and ckps's, no change. O2 sensors all unplugged to isolate, no change. Unplugging maf sensor and it dies immediately or won't start at all. I believe it may have a clogged upstream cat as it smells like firecrackers and has uneven temps fore and aft of said cat. Would that cause stalling though? And why does it idle so beautifully for 15-30 mins before dying? Any ideas on what to test for at the sensors?
Old Apr 21, 2026 | 02:17 PM
Vee's Avatar
Vee
EGR Valve perhaps?
Unplugging MAF sensor should kill the engine.
Without 02 sensors, fuelling stays in open loop. Its fueling off of a program instead of sensors. I wouldn't unplug those to find the problem.
Do you have a check engine light on? Can you read the codes.
Old Apr 21, 2026 | 02:48 PM
I removed the EGR valve recently and there slwasnt much carbon buildup, way less than the last XJ6 I owned, and I also swapped it with a valve from said previous XJ6. I have also run it disconnected without change, same issue.
I'll hook the O2 sensors back up and check for changes.
No codes currently besides a stored P0727.
Old Apr 21, 2026 | 03:36 PM
Don B's Avatar
With a good working catalytic converter, the temperature at the outlet should be significantly hotter than the temp at the inlet, typically at least 100° Fahrenheit higher. If the outlet temp is the same as the inlet temp, the cat is not lighting up. If the cat is obstructed, it can be tested for back pressure with a gauge that threads into the upstream O2S port. You may be able to rent a gauge set from a local auto parts store.
Here is the definition of P0727 from the ZF 4HP24 Transmission Diagnostic Trouble Codes Summaries manual. I don't believe a loss of engine speed signal at the Transmission Control Module will cause the engine to stall. More likely, the engine stalling is triggering the P0727 code:
I recall that with the 4HP24 transmissions, engine stalling when slowing to stop or make a turn could be caused by low transmission fluid. My assumption is that the torque converter was not releasing properly. Have you checked your fluid level?
Another possibility could be a failed fuel pressure regulator (FPR). One quick check is to pull the vacuum hose off of the regulator, crank the engine and look for wet fuel at the vacuum hose fitting on the FPR, which indicates a ruptured diaphragm.
Don
Old Apr 22, 2026 | 10:40 AM
Parker 7's Avatar
May be due for a main fuel filter change to ensure the fuel pressure at the idle is enough
And Dons mentioning of the Trans / Engine talking to each other as they dance together , clean the on the transmission body electrical connector , do not just twist off , trick involved
To know the O2 sensors and cats are regulating the total package correctly would be a short term fuel trim target 0 % ( this is a sample of the exhaust products ) , there is 1 fuse for all 4 ( sometimes 2 in Europe ) in the sensors heating elements for them to read correctly ( sensor physics )
The hook up of the O2 sensor connectors can be crossed that has caused others problems that do resolve on correct hook up
The O2 sensors return wire does have a needed ground on the rear engine firewall to protect the signal
The engine ECU does have a dedicated external ground strap for further protection
And the engine to starter to frame large ground strap , the frame surface condition effects many different sensors , the strap itself should be fine
By swapping ECU it is luck of the draw that the throttle position sensor at idle is a " match " with the different ECU , this match is referred to as " orientation " and is the special electrical test equipment adjusting the ECU to the TPS " null " or idle reading , on paper this is 0.60 volts DC on the middle wire with the TPS still connected
Someone by cleaning the EGR did recover the Idle and may have to consider the Rochester valve in the EVAP system
Old Apr 22, 2026 | 01:49 PM
andrea77xj6's Avatar
Default Stall
I had the same problem one year ago. I try to change everything. Finally i solved the issue when i replaced the O2 sensors.
Old Apr 23, 2026 | 04:12 PM
Appreciate all the replies! Will going through it all this week, currently don't have Wi-Fi out there but will try to keep y'all updated.
Old Apr 24, 2026 | 11:11 AM
Parker 7's Avatar
Keep in mind the O2 sensors are a different type and can be found here as a plug ready replacement , all 4 same
Premium Oxygen (O2) Sensors (13789) - Premium Oxygen Sensors - Bosch Auto Parts
Someone did find a Walker # and the originals are Denso and do use anti - seize but do not get on sensor tip
Only the rear 2 O2 sensors are for engine regulation so you have a swapping option , the pigtail wires are a brittle galvanized sort that are very brittle to twisting , I had broke wires sticking out of the insulation from previous owner
As you map your attack without full sensor information , approach from a least expensive , effort , easiest thing first like the grounds cleaning
And don't forget the main fuel filter change as probably always neglected , flow arrow to car's outboard and look for the O - rings hidden inside the filter ends , tank can sometimes on this model be siphoned with a 7 foot X 1/4 inch hose by the foot at the hardware store , but your still going to get wet
On this model the CKPS can fail without giving a code of P0335 , it is needed for fuel pump enable and that signal aspect can be failed to be discerned by the fuel pump control circuit but still give good starter tach of 300 RPM , a good CKPS will read 1300 ohms as a basic meter reading
You can demand the fuel pump on by a jumper between socket 3 and 5 , this will drain battery with keys in pocket . Best with medium gauge wire with blade type wire ends for best available current to properly power pump.
And we have the Inertia / Crash switch that can be fickle , this safety design drops out the fuel pump relay , this pic is someone's right hand steering and the switch will always be on right . A cheap try is to jumper the 2 white wires with a paper clip ( low current circuit )
Old Apr 25, 2026 | 06:34 AM
Spud Maat's Avatar
i had stalling issues... went through many many things. tried this, tried that.
i think there were certainly a few things that needed cleaning / replacing like injectors needed cleaning, maf replaced, etc...
ended up being coils.
there was 1 coil that appeared to be all good but once warmed up the resistance in the coil was dropping and causing a bad miss.
the coils came from a known working car but were cheaper aftermarket replacements.
after replacing the dodgy one with genuine second hand that was the final piece of the puzzle and car runs like a dream.
Old Today | 03:58 PM
Sorry all! I have quite the backlog of projects going on and the jag fell to the wayside for a bit. Finally getting back to it.
Don
I should've specified temps, yes the outlet temps are below inlet temps. Fluid levels in the transmission were a bit low, so i topped it up with the appropriate fluid, however the stalling has been happening when parked, not in gear. Checked FPR, no wetness.
Old Today | 04:04 PM
Main filter was changed when i did the fuel pump. I have removed that trans connector on a previous X300, will clean that on this one. Ground straps were early on my list but this car was very well taken care of, no corrosion at all. That said, I did clean them.
Old Today | 04:09 PM
It's a good thing this car is such a looker.
Old Today | 04:24 PM
Gentlemen! More testing along with a brand new CKPS and used MAF. It will run indefinitely if held off idle. However, it misfires when the rpm is not changed, revs up fine. It definitely runs best when cold, starts misfiring when its warmed up. Will be looking into testing O2 sensors today, as well as fuel pressure and cleaning EGR. Really trying not to throw parts at it but its hard to really sit down and diagnose when I have several other very large projects going at the same time.
Old Today | 04:51 PM
With an unplugged iacv and evap valve the car once warms idles at 1200 rpm (expected) but no longer stalls, side effect of the higher idle, fore-catalytic converters are reading over 700° F at the inlet and under 550° F at the outlet, will be taking it to an exhaust shop come the weekday to get those punched out.
Stillill
Oct 4, 2020 04:24 PM
tinyturner11
Dec 6, 2017 09:09 PM
jagastruckerhoodornament
May 3, 2014 04:03 AM
jaidank
Oct 2, 2013 05:40 PM
stypernut
Dec 2, 2012 02:38 PM
