P1000 help !!
04 XJ8 111k mi,
A few weeks back I got a P1647 code, (driver side up stream O2 is bad) the recommendations here said better to R&R all 4 , ok I'll do that.
And I thought I'd change the 7 remaining ignition coils that I didn't do a few months ago (#5 failed so I just did that one) I was waiting for the next oil change to R&R the other 7
So "while your in there" might as well do the plugs to
I just finished installing 4 O2' & 8 plugs & 8 ignition coils and it runs Worse, it starts fine but driving it , it has a surge
I couldn't afford all new Denso parts so I got the less expensive brands
I used my new scan tool to see what the problem is, it only shows ( P1000 System check not completed since last memory clear )
How do I get past that code to find the surging problem, I was hoping the scan tool would take me straight to the bad part.
I have absolutely no idea where to go from here
Don't panic but this could be painful, depending on whether the parts are good ones. Let's for now hope they are.
Two main things to do to get data to help diagnosis:
1. see which OBD monitors are unhappy (not set aka not ready aka not complete)
2. go for a drive to warm engine up then park and look at the fuel trims. 4 figures at idle & then rev to 2000-2500 and same 4 (STFTs & LTFTs).
With luck you "just" have maybe an air leak.
I tried driving it but the surge is so bad it felt like it was going to stall out, I didn't want to have to tow it home.
If one of the non Denso parts are faulty then why wont the scan tool just tell me a p-code to go after just it did
when I had a bad ignition coil, all says now is > P1000 System check not completed since last memory clear
Is there another way to check it without using the method you mentioned ?
Can you hear an air leak when it's surging? Coils will cause a misfire, but not really a surge like that, they either work or they dont.
Are you sure all your O2s got plugged into the correct connectors? I don't know if they reach but if they were swapped it can do funky things.
I would go over all the stuff you removed during the repairs, and look for something left loose. Codes are usually only for electronic faults if they pop up right away. If something is mechanically leaking or loose it may take some time to show a fault, and it would be a generic 'system lean' code that wouldn't help you find it anyway.
I was driving so I couldn't hear anything , I will run the mtr w/hood up and cover off
What started all this was the O2 code P1647 it said the driver side up steam O2 was bad, Can I then assume that
since I'm not getting that code now that all 4 O2's are OK ?
I will double ck the O2s are wired correctly.
Thanks ..
Thanks ..
