Rear hub bearings 1985/12
Old Apr 28, 2026 | 06:23 AM
iramphal's Avatar
Question Rear hub bearings 1985/12
Prepping to rebuild the rear suspension unit, so gathering up the required parts.
Does anyone have the part numbers for the inner and outer tapered bearings and their races? Not the Jaguar part numbers, but the generic ie. Timken numbers etched into the actual bearings/races. I understand that bearing such as these all carry the same numbers, regardless of the actual manufacturer. I'm also looking for similar info for the inner and outer needle bearings for the lower wishbone (fulcrum) arms. I plan to pick these up from my local bearing supply shop. Ian
Old Apr 29, 2026 | 01:48 AM
Greg in France's Avatar
I honestly think you will do better to buy an entire kit from a specialist (eg Manners) as they have all the seals, thrust washers, tubes and bearings you will surely need as well
Old May 5, 2026 | 11:25 PM
Jagboi64's Avatar
For the hub (wheel) bearing the numbers are:
Inner: 18520/18590
Outer: 18620/18690
As a note, when I rebuilt a differential a year ago I bought Timkin brand bearings, made in USA and they were out of tolerance, I could not press them onto the carrier hub. I then bought a set of Koyo bearings, 3 parts made in China and one part made in Japan and they fit perfectly, just as the original Made in England Timkins did. So don't necessarily shop for new Timkin bearings only thinking they will be the best for the job.
I don't have a note of the fulcrum shaft and wishbone bearing numbers. Can you take apart your old ones to read the numbers off them?
Old Yesterday | 01:37 AM
These were the items I was referring to about buying an entire kit as there are other parts you will need besides the bearings, such as shims and spacers.
This about setting up the hub endfloat, in case it helps
https://www.jaguarforums.com/forum/x...ebuild-225834/
BenKenobi
Aug 5, 2023 11:56 AM
nilanium
Apr 30, 2023 11:09 AM
MaxTorq
Oct 23, 2020 07:48 AM
nakuttaja
May 29, 2020 12:37 PM
bhmaxjag
Mar 16, 2009 10:32 AM
