Hidden Antenna Recommendations - '95 XJS Convertible
Old May 1, 2026 | 10:01 AM
03_jagXJR's Avatar
Default Hidden Antenna Recommendations - '95 XJS Convertible
Does anyone have any good recommendations for a hidden antenna for the XJS and an optimal mounting location? I recently picked up a '95 Convertible with an aftermarket head unit that is soon to be replaced with the Continental TR7412UB-OR. The existing head unit picks up a single FM channel, and quite poorly. I'm expecting that this is due to it being connected to the original antenna, which doesn't get a power signal to raise/ lower when the radio is on or off. I don't want to use the original antenna - no clue if it raises or lowers and no interest in finding out. I'm thinking of a hidden antenna that would mount in the top center of the windshield trim under the center cover and running the cable behind the A-pillar covers, does that seem a reasonable location or would the windshield frame generate too much interference?
Old May 1, 2026 | 12:17 PM
Vee's Avatar
Vee
Might be easier to find out if the antenna goes up or down....
Old May 1, 2026 | 12:59 PM
03_jagXJR's Avatar
As mentioned, absolutely zero interest in the original antenna.
Old May 1, 2026 | 06:12 PM
davchr's Avatar
There are a few hidden antennae on Amazon. Pick one and try it. If you don't like it, send it back. At the end of the day I think you will find the original antenna, when extended, works better than any hidden one.
Old Today | 02:42 AM
Keesh's Avatar
The antenna is probably receiving a signal but is simply stuck because the grease in the mechanism has dried out or the antenna was never lubricated and moves too stiffly.
darbysan
Aug 13, 2019 07:14 AM
Spikepaga
Jul 21, 2019 09:15 AM
NCJagman
Sep 25, 2016 01:43 PM
ukester
May 23, 2014 03:34 PM
perezal
May 17, 2014 07:35 PM
