Hidden Antenna Recommendations - '95 XJS Convertible
Does anyone have any good recommendations for a hidden antenna for the XJS and an optimal mounting location? I recently picked up a '95 Convertible with an aftermarket head unit that is soon to be replaced with the Continental TR7412UB-OR. The existing head unit picks up a single FM channel, and quite poorly. I'm expecting that this is due to it being connected to the original antenna, which doesn't get a power signal to raise/ lower when the radio is on or off. I don't want to use the original antenna - no clue if it raises or lowers and no interest in finding out. I'm thinking of a hidden antenna that would mount in the top center of the windshield trim under the center cover and running the cable behind the A-pillar covers, does that seem a reasonable location or would the windshield frame generate too much interference?
There are a few hidden antennae on Amazon. Pick one and try it. If you don't like it, send it back. At the end of the day I think you will find the original antenna, when extended, works better than any hidden one.
