2000 Jaguar S-Type 4.0 Booster Pedal Force Switch
Old Yesterday | 06:19 PM
Choptank61's Avatar
Default 2000 Jaguar S-Type 4.0 Booster Pedal Force Switch
I have no clue what this alludes to. Is this the actual switch or the booster, which I did not know it even had? Could it have anything to do with DSC failure?
Old Today | 09:23 AM
clubairth1's Avatar
Community Influencer
Start with searching this forum for that code. Then do a general search on that code.
Report back with what you found out.
Old Today | 10:17 AM
motorcarman's Avatar
C1287 DSCCM Dynamic stability control Active brake booster release switch circuit fault
DSCCM to release switch reference voltage circuit (FH51-40):
open circuit, short circuit to ground, short circuit to B+ voltage, high resistance
Active brake booster release switch failure
NOTE: Control module calibration using PDU is required when the fault is
repaired and the DTC is cleared. MIL will flash to indicate that
configuration is required
File Type: pdf
Ernest Knox
XJ40 ( XJ81 )
Jul 28, 2021 07:01 AM
rgp
Sep 23, 2020 03:47 AM
Asdrewq
Jul 22, 2020 05:51 AM
prbloch
Jul 9, 2014 01:01 PM
