Gear selector knob not rising
Old Yesterday | 12:39 AM
Beedij's Avatar
Default Gear selector knob not rising
I have a XF 2014 3.0l V6 supercharged. AJ126 engine. It has 77,000 miles on the clock.
I have a developing problem. Yesterday when I got in the car to go home from work the engine started as normal, but the gear selector knob did not rise. I switched off and then switched on again and this time the selector knob rose and I drove home normally.
This morning getting in the car to go to work the engine started normally but this time the gear selector knob only rose about a quarter way and on the dashboard, I got parking brake fault and gearbox fault warnings. I switched off and on again and the everything was normal.
Is this an early indication of a developing fault?
Old Yesterday | 09:56 PM
double-o-seven's Avatar
I suggest spraying WD-40 Silicone Lubricant spray (not the regular WD-40), with the straw shooting the lubricant into the circumference of the rotary dial. Most likely, this will fix your problem.
MarcelE
May 29, 2024 04:53 AM
mrs_sutsie
XF (X260)
May 12, 2023 01:47 PM
EngshMan
XE ( X760 )
Mar 10, 2018 08:02 PM
denne
Jul 10, 2015 07:26 AM
BrownRobin
May 26, 2013 03:20 AM
