XJ ( X351 ) 2009 - 2019
pinch weld jack pads
Old Today | 08:39 AM
12jagmark's Avatar
Default pinch weld jack pads
I came across this jack adapter for pinch welds that Harbor Freight sells for $14.99 each.
https://www.harborfreight.com/magnet...ter-70888.html
Have any of you used this jack pad pinch weld adapter?
There are cheaper ones on E-bay too, including magnetic metal ones like this, rubber ones and also pinch weld adapters for jack stands too.
https://www.ebay.com/sch/i.html?_nkw...om=R40&_sop=15
Any suggestions ones that you have used?
Old Today | 10:46 AM
clubairth1's Avatar
Community Influencer
With the Aluminum body I don't think the magnetic will do any good.
I got a set when I purchased my Bendpak lift but were a pain to use. Positioning them correctly and then they stuck to the car when I lowered the lift.
I hate to say it but I lift my XJ using a rubber pad on the pinch weld lifting points. No damage that I can see other than a bit to the rubber pad.
Old Today | 11:01 AM
farm-jag's Avatar
I have never used these in my life and have been wrenching for 35 years. I just use the rubber pad that are on my jack. Never ever had a problem. However, at the same time they aren't going to hurt anything so if you want to get them I say go for it!
Ant Buck
Feb 22, 2025 03:00 AM
Dr. D
Mar 27, 2020 12:10 PM
TreVoRTasmin
Mar 10, 2020 11:24 PM
04Xjrsteve
Feb 24, 2016 08:35 PM
BritCars
Jun 12, 2015 06:58 PM
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
