2014 XJR possible engine issue
Old Jul 26, 2021 | 06:01 AM
Woosy's Avatar
Default 2014 XJR possible engine issue
Whilst out for a run last Saturday I had to accelerate quite hard to pass another vehicle. The gearbox kicked down a couple of gears, at this point whist accelerating I glanced in my rear view mirror to see a cloud of blueish smoke. Repeated the action to see the same result. I’ve checked coolant no oil and no loss, Underside of the oil filler cap, no emulsified oil. On cold start engine doesn’t burn any oil. Been in touch with the Indy who looks after my car and it’s booked in for next week. I don’t think it’s rings or valves, although without a test can’t be sure. I think it maybe a sensor or injector which is faulty and maybe over fuelling the engine. Which ever way it goes it’s going to be expensive me thinks ☹️
Old Jul 26, 2021 | 08:32 AM
I would also think sensor or injector but only a compression test and a diagnostics session is going to confirm possible causes. Good luck.
vincent661983
Feb 18, 2020 03:10 PM
JessN16
Nov 19, 2017 09:44 AM
Bcrary3
Aug 13, 2015 01:51 PM
tibam13
Jun 1, 2015 06:08 PM
sean
Aug 26, 2014 09:40 AM
